Old 10-06-2005, 08:09 AM   #16 (permalink)
DallasRover's Avatar
Another Bonus..................
Gas
Beer is proof that God loves us and wants us to be happy. ~Benjamin Franklin
1989 RR Classic
1969 Series IIA
3 Kids in College...........
DallasRover is offline   Reply With Quote
Old 10-06-2005, 08:48 AM   #17 (permalink)
TerryS's Avatar
The $50 shutoff at the pump is setable by the station. They aren't doing this for rationing, but the oil companies have had alot of non paying credit card users when their bill gets up there. The Mobil I use (12 miles up the road in Massachusetts is an average of 21 cents per gallon less than Northern CT) used to have a $50 CC limit, but when the prices shot through the roof, they either raised it, or took it off entirely. I fill my 110 on an average on once every 10-12 days, and don't until I'm less than a 1/4 tank, so it takes $50-52+ each time I fill. On occassion, I'll take a couple gerry cans too, so it goes much higher, but has never shut off before I'm done pumping.
Old 10-06-2005, 10:37 AM   #18 (permalink)
LRR219's Avatar
Pump Stopped Me Here At 40 Bucks.... What A Joke
Don't follow us, you'll get stuck.
LRR219 is offline   Reply With Quote
Old 10-06-2005, 11:07 AM   #19 (permalink)
OkieRover's Avatar
Gallery: 3
I got off the phone with my buddy who works at a bank.
He said the 50$ is a "pre-authorization limit" set by the bank.
He also said it is very common and been happening for a while.
We have never run into it before is why.
IF you go to truck stops for fuel you may encounter higher pre-authorization amounts.
Old 10-06-2005, 01:31 PM   #20 (permalink)
94 Defender 90
cellulararrest's Avatar
Originally Posted by rutlanddisco
Call me crazy but I thought we had to use premium, no if ands or butts?!
2000 disco se7
depends on if your truck pings or not with lower octane fuels. If it runs fine on a lower octane, fine. If your truck pings that's a problem and is most likely causing unnecessary wear in your engine.
S.N.H.L.R.
cellulararrest is offline   Reply With Quote
Old 10-06-2005, 01:36 PM   #21 (permalink)
BIRD's Avatar
FLY WHEEL,
I have been using 87 octane for just over 3 weeks now. I do see any change in engine performance. I do however hear a slight cliking sound from the engine, but I do not think it is the valves because it comes and goes and does not change rythem when I go faster. I think I might go back to using the 91 octane when the price comes back down.
BIRD is offline   Reply With Quote
Old 10-06-2005, 02:35 PM   #22 (permalink)
OkieRover's Avatar
Gallery: 3
My ping sound is the catalytic converters being basically hollow.
Old 10-06-2005, 10:13 PM   #23 (permalink)
Proud to be an Infidel
FlyWheel's Avatar
Originally Posted by BIRD
FLY WHEEL,
At 54K miles I too get that loose rattle in the bowels of my Landy. It sounds like a Wrist Pin. I use good synthectic stuff so maybe it just typical acceptable Rover Tolerance.....who knows
2001 Disco SE7
.......eventually they will run out of suicide bombers.....
FlyWheel is offline   Reply With Quote
Old 10-06-2005, 10:13 PM   #24 (permalink)
FlyWheel's Avatar
FLY WHEEL,
At 54K miles I too get that loose rattle in the bowels of my Landy. It sounds like a Wrist Pin. I use good synthectic stuff so maybe it just typical acceptable Rover Tolerances.....who knows
2001 Disco SE7
