Overheating disco 2 - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 9 (permalink) Old 03-13-2017, 05:22 PM Thread Starter
Grayson Hestir's Avatar
Quoted: 0 Post(s)
Overheating disco 2
Forgive me if there are 7.2 million overheating threads, but this is the first time posting, as well as asking for help after owning my discovery 2 for over a year. It's a 2004 SE with about 119k on the trans and body, and 150k on the 4.0 I popped in there after I dropped a sleeve at 99k. Went through the 4.0 with new gaskets, pumps, etc. did not change out the oil pump gear, but most everything else. It was snowing one day about a month ago,(I live in upstate South Carolina), and I drove the truck about 30 miles home, got in my driveway, temp shot up, and it blew off my expansion tank hose. (It's blown off before and cracked the plastic piece on the rad that it secures to). I've reclamped it since then. After that, it would idle for about 20 minutes, temps would begin to climb, but not reach the oh crap line. I usually cut the car off anyway out of fear when this happens. Thermostat seams to be opening. I purged the CRAP out of the cooling system, and heater core. I replaced fan clutch, and ordered a 180* warm climate t/stat from rovers north, and an oem rad. I flushed mine, it had great flow, with no hesitation..? But drivers side of the rad was way warmer than the opposing side, so I decided to order a new one. All my hoses are the same temp, and flowing correctly, I think... my next idea is a block test, but I had that gasket replaced 18 thousand miles ago. I never try to drive it hot, i always call a tow on the spot, and I'm oddly missing coolant constantly, (not in my oil, my heat works great, no white smoke on start). I know to check the top corner of the front cover, but I figure if it was leaking there I would see spots in my driveway, at least. Pulleys could use replaced, as some are getting tight on me...what am I missing here?
Grayson Hestir is offline
post #2 of 9 (permalink) Old 03-13-2017, 05:53 PM
tyl604's Avatar
Quoted: 55 Post(s)
Well, what stands out is that you did not mention having another way to monitor the water temp other than the stock gauge. That gauge does not click up or down in increments, it just magically goes to hot after you basically overheat. And usually it is too late then and you have blown a gasket.
So I would get something. I have a head up display which plugs into the OBDII socket and have been happy with it. But you need something.
Sounds like you need to check the compression to see if you have blown another head gasket. Maybe not; hope not.
tyl604 is offline
post #3 of 9 (permalink) Old 03-14-2017, 05:46 AM
Quoted: 290 Post(s)
Have you replaced the radiator cap? You shouldn't be blowing off hoses.
If you've been reading about overheating, then you no doubt know that the temp gauge is a decoration. It moving past mid-point is usually the oh crap line.
If you're continually losing coolant, that's a bad sign. It's going somewhere. If it's not in the crankcase, it's either leaking into a combustion chamber or out of the engine. Your first check is to warm it up well and hook a pressure tester to it. If it won't hold pressure look for the external leak. If no leak, pull the plugs and see if you have leakage into the cylinder.
Have you checked the electric fan? Do you have the bleed screw tee on the top hose?
Some unclear points:
How often does it overheat, and is it low on coolant when it does?
Is the radiator new and if so, how recent?
Block test? gasket?
CT090 is offline
post #4 of 9 (permalink) Old 03-14-2017, 07:34 AM
Drives like an old man
discomania04's Avatar
Quoted: 31 Post(s)
Garage
Might I suggest that, while the radiator is out, that you replace the water pump as well? I'm going to replace my rad next month and will do the pump at the same time. Looks dead easy and I've heard of water pumps with plastic impellers wearing out; I'm taking no chances. They're cheap and easy, just like I like 'em.
2004 Disco II, bone stock, daily driver (gasp!)
discomania04 is offline
post #5 of 9 (permalink) Old 03-14-2017, 09:43 AM
Quoted: 290 Post(s)
That's a good suggestion. Rockauto has a Delco- new, not reman. Metal impeller. $65.
Cavitation eats those plastic impellers up.
CT090 is offline
post #6 of 9 (permalink) Old 03-17-2017, 04:19 AM
Quoted: 290 Post(s)
Originally Posted by sacer bonnie View Post
i think you need to replace the radiator
Based on what? He needs to go through some diagnostic steps before determining what's wrong. He could replace every piece of the cooling system and possibly find out he has a blown head gasket.
If money is no object, just take it to a shop- or buy a new car.
CT090 is offline
post #7 of 9 (permalink) Old 03-31-2017, 09:00 PM
DISCOlorado's Avatar
Quoted: 3 Post(s)
Do you see any physical leaks, coolant leaks?
DISCOlorado is offline
post #8 of 9 (permalink) Old 04-01-2017, 06:28 AM
Quoted: 290 Post(s)
hi,
it is just my opinion, maybe you can ask the Professional staff for advice.
best wishes.
People come to sites like these to get answers. If they knew what they were doing they wouldn't be here. When members respond with repair advice/information, I think may assume that person knows what they are talking about. You posted that he should replace his radiator. Then you later answered that it was your "opinion". But you asked no questions and the OP has yet to answer any of the other poster's questions. In reality it could be a number of issues. We are far away from being able to provide any quality repair advice.
Short version- if you don't know, say you're guessing based on zero information. If you think you know, say "it could be" and describe why you think so. If you "know", state exactly why.
People don't need internet forums to throw money at un-needed repairs.
CT090 is offline
post #9 of 9 (permalink) Old 04-03-2017, 07:09 PM
Quoted: 47 Post(s)
He stated that the radiator was replaced. Well, he said that he ordered 1 so we have to assume it was replaced. Otherwise everyone would be asking why he hasn't swapped them out yet.
Chubbs878 is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rovers Only General Forums > General Land Rover Discussion
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
My 01 disco 2 is overheating please help!!! Miked121 Discovery Series II 9 05-03-2016 05:38 PM
New here, 03 Disco overheating...... joesfiero Discovery Series II 33 07-26-2013 08:36 PM
'94 Disco I with a 4.6 > Overheating rovertrain Discovery Series I 16 11-02-2010 01:29 PM
'99 Disco overheating 123Guy Discovery Series II 5 07-19-2008 09:19 PM
Disco Ii Overheating (need Help) GOTMUD? Discovery Series II 1 07-17-2005 05:53 AM
You may post new threads
You may post replies
