Old 06-04-2008, 03:25 PM   #1 (permalink)
Default Pls Help 1999 Range Rover 4.0 MIL light
I have read your postings on the 2001 Range Rover Check Engine Light
I have a 1999 4.0 Land Rover that is giving me these codes
I had the P0305 misfire code and replace all spark plugs and spark plug wires
I still had the code
I just replaced both heads because of lose valve guides and though that would solve the problems. The valve guides were in bad shape. Prior to the replacement I had the P0305 misfire cyl 5 code
Now I have these
I clear the codes. The engine runs fine until about 2400 rpm under load and no load and the I get these codes. I feel the engine miss and the MIL light flashes
P0137 O2 Circuit low voltage (bank 1 sensor 2)
P0305 cyl 5 mis fire
P1319
Misfire with Low/Empty fuel drive cycle C: signal out of range. Above Max
The dealer told me it was a slipped sleave in the cylinder. I have no coolant leaks and no coolant in the oil. I have no oil leaks.
What next. Coil? O2 sensor. I have a good OBD that has freeze data gathering.
any ideas, I love this car
maysd is offline   Reply With Quote
I need help buying a Range Rover bmilcetich General Land Rover Discussion 10 08-29-2008 06:38 PM
2001 Range Rover HSE Check Engine Light umoms Range Rover P38, Mk III and Range Rover Sport 21 05-02-2008 04:53 PM
2008 Land Rover Range Rover review torres Range Rover P38, Mk III and Range Rover Sport 0 07-30-2007 08:31 AM
1999 Land Rover Range Rover 4.0 SE V8 Cylinder 4.0 Only $7500 sky2you Land Rover Vehicles 0 06-19-2007 06:37 PM
1999 Discovery Light bulb guide darkknight1999 Accessories 3 03-22-2006 09:31 AM
