Old 02-02-2007, 03:37 PM   #1 (permalink)
Doesnt like the limb on paint sound....
ClassicBluey's Avatar
Default Propeller shaft tool alternatives
Im going to do my rear output shaft seal on my LT230 this weekend.I wanted to know what i can use besides the "propeller shaft holding tool" to hold it while i loosen the nut.Not the most complex problem,but i dont want to jam a large screwdriver where it doesnt belong (dirty jokes aside,its just not right )
So if anyone has used an alternative tool let me know.
2003 Disco II
Mud tires.......Thats it......
ClassicBluey is offline   Reply With Quote
Old 02-03-2007, 05:49 PM   #2 (permalink)
antichrist's Avatar
Set the parking brake.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
Old 02-03-2007, 07:46 PM   #3 (permalink)
Parking brake and rear drive shaft have got to be removed to get to the rear oil seal or the propeller shaft.Its behind the parking brake.
2003 Disco II
Old 02-04-2007, 05:33 AM   #4 (permalink)
You could put the brakes on and block the pedal with a piece of wood.
s3landy is offline   Reply With Quote
Old 02-04-2007, 10:12 AM   #5 (permalink)
Im gonna make one.If i blocked the brake pedel i believe there would be too much slop.I would never get it torqued back to spec.It must be solid and unmoving.So ill take on the task of making one tomorrow.
I would just buy one.But i cant seem to find one anywhere
2003 Disco II
Old 02-05-2007, 07:43 AM   #6 (permalink)
antichrist's Avatar
Ah, sorry, thought you meant the propshaft nuts.
Lock the center diff, put it in low 1st and chock the wheels.
But it should be easy to make something.
Use a piece of flat stock about 2' long and as wide as the flange, torch or drill a hole in the center at the end large enough for your socket and then drill two or three holes so you can bolt it to the flange.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
