Old 03-05-2008, 07:49 PM   #1 (permalink)
LandGrover's Avatar
Default Rover piggyback?
In May I'm moving from Kansas City to Providence. The problem is that I have to get both vehicles out there. I have a mildly modified 95D1 and my wife drives a '00 DII stock. We don't want to drive both trucks separately if that can be avoided; besides getting killed on gas, we'd like to be together for the 1500 miles. Does anyone have any advice on how to pull this off? Is there a pretty reasonable way to have one disco tow the other? Piggyback? Has anyone ever tried shipping a vehicle--probably also pricey? Any advice would be appreciated. Moving is expensive enough, so cheaper is also better.
2000 Disco II
1995 Disco I
LandGrover is offline   Reply With Quote
Old 03-05-2008, 08:11 PM   #2 (permalink)
2004 Discovery II driver
shipping a vehicle is only a few hundred usually. i think i was qouted $572 to ship an FJ cruiser from texas to florida.
i think if you disconnect the front driveshaft and leave the vehicle in nuetral you can town it on a uhaul style car hauler. but i'm not positive.
stolenheron is offline   Reply With Quote
Old 03-05-2008, 09:19 PM   #3 (permalink)
Rocky Mountain High
Funrover's Avatar
Been there, done that. I would simply remove the rear driveshaft once you have the rover on the trailer. You will be fine!
Old 03-05-2008, 09:24 PM   #4 (permalink)
Rocky Mountain High
Funrover's Avatar
Look into renting from U-haul, check straps after the first few miles then check when you get gas. You should be fine as long as you remove the rear driveshaft from the 95 (I would pull with the DII)!
Old 03-06-2008, 04:06 PM   #5 (permalink)
LandGrover's Avatar
Those pictures are great. The piggyback could work. I am going to call Uhaul and see what they have. I was worried that their trailers may have weight limits, hopefully not.
2000 Disco II
1995 Disco I
Old 03-06-2008, 04:15 PM   #6 (permalink)
ok, yeah i knew i wasn't all the way right. REAR driveshaft lol
Old 03-06-2008, 06:50 PM   #7 (permalink)
Rocky Mountain High
Funrover's Avatar
Yeah you will be fine there..
Old 03-07-2008, 04:29 AM   #8 (permalink)
pickuprover's Avatar
If you are going that far, I would invest in the flat bed hauler (uhaul has them). Less wear and tear on the truck, easier to manouver, don't have to drop the driveshaft.... Also, check the states regs that you are travelling through, I know that here in Canada, there are some that will not let you tow a vehicle of similar size and weight. (due to the fact that you are doubling the inertia but not the braking power and as well, the tow vehicle may not have the mass to control the towed vehicle....) Usually tho a flat bed gets you around this as the trailer should have electric brakes.....
Andrew Barr.
1972 Series III 109.
"the Tin Turtle"
"However, that was his ploy and I caved....totally caved... LOL!" Jellijo
pickuprover is online now   Reply With Quote
Old 03-07-2008, 06:48 AM   #9 (permalink)
XtremeMarine's Avatar
Is everyone posting here forgetting that Grover has a tow rating of 5500 pounds. You are encouraging him to damage his vehicle. Sure, what Fun did is possible, and is okay for a short trip, maybe even a couple of hundred miles. And it is correct that a flat bed trailer is better. But the truck, even on a tow dolly is over the rating. And it is MOST LIKELY that something will get damaged.
Since they both have the same tow rating, if you decide this is the way you want to go; use the 95 since it is the older vehicle. The DII will be more expensive to repair.
Good luck.
Old 03-07-2008, 08:26 AM   #10 (permalink)
Rocky Mountain High
Funrover's Avatar
Good luck.
With a flat bed you are gonna cause issues, not with a dolly! I have done that tow many times. The flat beds (renting from u-haul) get you close to the 5500 limit. With a tow dolly it's more or less like a tow strap for weight (I realize there is more, but you get the idea)
Old 03-07-2008, 08:31 AM   #11 (permalink)
Fun; what's your RRC weigh? On a truckstop scale, my DII weighs in at over 6000 without all of the offroad kit that I bring when I offroad.
Old 03-07-2008, 09:12 AM   #12 (permalink)
D2s weigh around 6024lbs with fluids filled stock....
Old 03-07-2008, 09:57 AM   #13 (permalink)
There's just no way to safely tow 6000 + pounds, 1500 + miles, with a vehicle that only has a 5500 pound tow rating in Hi. And I don't think he wants to drive 1500 miles at 20 mph in 4Low. LOL!
Old 03-07-2008, 10:00 AM   #14 (permalink)
oh, but it would really let you take in the sights!
Old 03-07-2008, 10:16 AM   #15 (permalink)
1991 RRC 189060 miles and going
SafariDave's Avatar
When I visit my LR mechanic he prefers to tow the DI & DII with Classic Rovers From his parking area into the lifts in his garage. He says he does not trust the Disco's as much with towing he is afraid something might go in the discos.
The City is a Jungle.
1991 RRC
1988 RRC (sold)
SafariDave is offline   Reply With Quote
Famous Owners of Land Rover vehicles Bleed Green RRC The Lounge 37 08-28-2006 12:40 PM
Land Rover Frequently Asked Dumb Questions (very long...but funny) JungleRR General Land Rover Discussion 0 05-26-2006 09:37 AM
Land Rover: Truly 'Extraordinary' Serg General Land Rover Discussion 0 01-30-2006 11:37 PM
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 17 01-29-2006 01:18 PM
Range Rover Sport Seems to have it all Serg General Land Rover Discussion 1 12-05-2005 12:54 AM
