seafoam - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
Old 01-21-2013, 10:59 AM   #1 (permalink)
oilladrover's Avatar
Default seafoam
just did a treatment to the rrc88. waiting the 30min to go drive it. will see if it dose any good. I will say this was way easy. no tools needed. just pull the line and plug from the break boost and poor slowly. son kept rpm at 200. went smooth. I also put 16oz in the tank for the injectors. let see what happens.......
oilladrover is offline   Reply With Quote
Old 01-21-2013, 12:27 PM   #2 (permalink)
Default seafoam update
ok so not a lot of smoke. at least not like I thought there would be.
however I have power were there was none before. I have pick up I did not know the old girl had.
the efi light is on but I read that should go off in a day or two so we will see. ill up date u on it as it dose or dose not go off.
also the idel speed seems a bit ruff now. going to adjust it.
If you ask me I say do it. there was a noticeable change well worth the 16$
Old 01-26-2013, 01:44 PM   #3 (permalink)
If you are forced to use e-10 fuel you might want to take a look at this:
Is your gas additive safe with E10 fuel?
All the best!
Tom
2004 DII SE - OME 3" lift - HD springs, shocks, and steering stabilzer.
260/55/18 General Grabbers tires
Tom Woods front driveshaft. Borla S.S. cat-back exhaust.
Rovertym slimline front bumper + 9500 lb winch
Atlantic British heavy duty, steel rear bumper
ARB sidesteps/tree sliders
Lifetime labor warranty... me
2008 MB E320 Bluetec Turbo
tcpfl is offline   Reply With Quote
Old 02-10-2013, 04:48 PM   #4 (permalink)
All the best!
seafoam is now safe to use with ethanol. make sure the can says so. there are two types out there...
Old 02-17-2013, 07:45 AM   #5 (permalink)
Awesome... I'll look for that when it's time for the next maintenance.
Thanks!
Tom
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rovers Only General Forums > General Land Rover Discussion
Seafoam stb616 Discovery Series I 3 12-04-2012 06:27 PM
SeaFoam Davisch75 Range Rover Classic 1 03-17-2010 05:01 AM
Seafoam mtnance Discovery Series II 5 07-01-2009 01:10 PM
seafoam??? tbrisk Discovery Series II 7 06-16-2008 09:43 AM
Seafoam - what does it do? Grid_Lock Discovery Series I 1 04-12-2007 11:17 AM
SEO by vBSEO 3.3.2
