Hi all. I've been on here often but never needed to post as there is a wealth of information. But this time is different.
I have a 2000 D2 135000miles. Recent work done (two months ago):
Purge valve
Front O2's
MAF
Here's the problem:
Stalled out 4 times yesterday in two "events". First time stalled 5-8 minutes after start up on a mild hill. Radio was up so I couldn't hear any sounds. Started up after 15-20 hard cranks. Stalled about 2 minutes after I got her going again.
Second "event" was on the way home. Stalled on another mild hill, more of a bump, after slowing to a stop and accelerating. Radio was off. It died down like it was out of fuel. Sort of a choking out. Started again in 10-20 hard cranks with battery almost drained. Made it home and parked. Restarted the vehicle and had a really rough idle.
I'm at a lose as to what the issue is. I drove it in this morning after letting her warm up. No stalling this time. Had a gauge hooked up to monitor temp, rpms, etc. She stayed steady in the hour of city driving with temp static at 194 and rpms at idle around 675.
I am ordering a CPS, and new wires. 8mm kingsbourne. I will also be re leaning the MAF, IACV, and throttle body. I want to test for vacuum leaks. Any tricks? I was going to just do the "spray it down with throttle body cleaner and listen" method.
Any ideas about this dieing truck would be greatly appreciated. Thanks all.
Purge valve
Front O2's
MAF
Here's the problem:
