Old 03-30-2008, 04:56 PM   #1 (permalink)
Arrow starter issues
The rover ive been looking at has just decided not to start. According to the current owner he's tried jumping the monster and had no luck - however the electrical is still working. This would lead to believe to be the starter or ignition system - 1) is it very expensive to fix 2) is it a quick diy job or should a real mechanic take a look. 3) is it just a sign that the electrical will go?
skunkworks is offline   Reply With Quote
Old 03-31-2008, 06:54 AM   #2 (permalink)
antichrist's Avatar
1 - Depends on what the problem is and who does the work
2 - Depends on what the problem is and who does the work
3 - No
If you do it yourself probably the most expensive thing would be a new starter for less than $300 for a new one.
All this depends on what Rover it is, you don't say.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
Old 03-31-2008, 01:27 PM   #3 (permalink)
1992 rrc
Old 03-31-2008, 01:31 PM   #4 (permalink)
OkieRover's Avatar
Gallery: 2
I just recently had my 1993 leave my daughter on the side of the road.
I would not start. Starter would not turn over.
I thought it was the starter. But after taking it out and testing it by using the jumper cables the starter worked fine.
Negative to the case and short out the bendix to the post. Starter should flip over and the bendix kick the shaft out and spin it.
Anyway. I finally thought it had to be a relay failed, but it turned out to just be the ignition switch was giving us trouble. I refitted the wires end of the switch back on to the tumblers and fired the Rover right up.
I punch my clown daily.
Old 06-08-2008, 11:48 AM   #5 (permalink)
well my discovery TDi when i am driving down the road it cuts out there is no air in the fuel system has anyone got any ideas what this might be thank you
william is offline   Reply With Quote
Old 06-08-2008, 01:06 PM   #6 (permalink)
Do your self a favor and don't buy it unless the owner has the repairs made and paid for.
Old 06-10-2008, 09:46 AM   #7 (permalink)
antichrist's Avatar
Definitely not your starter. Post your question in the Disco section, something like "TDi dies while driving" and provide a more detailed description of what the symptoms are. "cuts out" can mean a lot of different things to different people.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
Starter in Pieces Please HELP!! (pics included) xtremehp13 Discovery Series I 3 08-26-2007 03:39 AM
Slow starter motor landynutkieren Series Land Rovers 14 04-17-2007 01:13 PM
New Starter won't start . . . CurvyRover Range Rover Classic 2 10-05-2005 08:52 PM
Series III starter problem cutnfell Series Land Rovers 4 06-21-2005 06:02 PM
1991 Range Rover starter replacement glenncof Range Rover Classic 0 09-16-2004 10:20 AM
