Originally Posted by storage74
Hi Folks, I need help from the experts! I have a 2001 Disco II and my steering wheel wobbles when I get closer to 50mph, then steadies itself after it shifts gears to about 53ish. There's a huge giration that makes the truck shake. At first I thought it was the steering stabilizer, but it isn't - I've replaced that. This all started when I switched out the wheels to some used LR3 wheels and tires.
What else would it be? Is it something I can replace myself or would I have to take it to the shop. I'm a little higher than a novice when it comes to repairs.
Thanks in advance for the great advice!
Check the wheel balance. It's a cheap fix, around here, tire shops will balance a wheel for $8 to $10 per wheel. Have you looked at your tire tread for unusual wear such as cupping?
2000 D2 SD w/BFG MT 255/85/16, 3" lift, ARB front bumper, custom rear bumper & rock sliders, Mantec snorkel, CDL, KMC rear diff guard, Columbia Rovers gas tank skid, LR front skid, RoverTracks HD tie rod, BajaRack low-profile roof rack
2000 D2 stock w/BFG AT-KO 245/75/16, KMC rear diff guard, RockStar Fab rear door panel
