Towing Capacity - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 16 (permalink) Old 05-31-2005, 03:31 PM Thread Starter
Quoted: 0 Post(s)
Towing Capacity
I was wondering if anyone could give me the specs for towing with a land rover and a range rover. I am looking to purchase one of these but am a little bit hesistant of whether of not it could tow a open trailer and a car. Thank you in advance.
RvS
listed is offline
post #2 of 16 (permalink) Old 05-31-2005, 04:27 PM
Disco's Avatar
Quoted: 0 Post(s)
The 1995 discovery has a towing capacity of 1650lbs (unbraked trailers) and 7,700lbs (braked trailer). The Range Rover would be the same.
Hope this helps.
Disco is offline
post #3 of 16 (permalink) Old 05-31-2005, 04:30 PM Thread Starter
Quoted: 0 Post(s)
thank you very much and that information is helpful.
RvS
listed is offline
post #4 of 16 (permalink) Old 05-31-2005, 07:12 PM
Super Moderator
02disco2's Avatar
Quoted: 0 Post(s)
Just a note on that 7700lb figure. That is the rating for low range, not high or standard. (I actually thought it was 7200lbs, that is what the D2 is anyway) Regardless though, I tow over 6500lbs all the time without a single issue. Just make sure the trailer is setup correctly and the load is balanced correctly, you'll be good to go.
Current:
2006 Mercedes-Benz E500
2004 Range Rover HSE - Overfinch Upgrades
2004 Infiniti QX56
Previous:
2002 Discovery SE
2002 Mercedes-Benz C32 AMG
1999 Audi A6 Avant
1999 Volkswagon Passat 1.8T
1997 Audi A4 Quattro 2.8
02disco2 is offline
post #5 of 16 (permalink) Old 11-14-2008, 04:30 AM
Quoted: 0 Post(s)
Im looking at a 96 Discovery to tow my 30ft camper.
The camper weighs 6720 lbs.
Would the Discovery tow if fine? Its not braked.
trigga is offline
post #6 of 16 (permalink) Old 11-14-2008, 04:42 AM
Rover-Holic and Admin
ArmyRover's Avatar
Quoted: 37 Post(s)
No it wouldn't that would be rather suicidal for a couple of reasons.
1 the weight is to much for a unbraked trailer and would cause a serious safety risk.
2. Your disco has a 100" wheel base and would get it's but whipped by something that long and heavy.
3. Buy a 3/4 ton or larger truck for that.
1972 MGB
2007 Chawton White LR3
Trident Green, 1983 110
Need new parts, genuine Land Rover, aftermarket and off road upgrades, Support the Vendor that supports the Land Rover Community and Forum
716-898-8153
Have a DII you need a drive shaft click here
Want a
best read this first
Need used parts?
ArmyRover is offline
post #7 of 16 (permalink) Old 11-14-2008, 06:22 AM
Quoted: 0 Post(s)
Ok thanks for the info. I was hopeing that would be my excuses to finely get my disco.
trigga is offline
post #8 of 16 (permalink) Old 11-14-2008, 08:07 AM
Rocky Mountain High
Funrover's Avatar
Quoted: 0 Post(s)
NO NO NO.... Don't do this!
My parents pulled a 25 (or 27') with their 97 Range Rover with the 4.6, It was braked and weighed in around 5800 with everything packed. I wouldn't go past that.
Funrover is offline
post #9 of 16 (permalink) Old 11-14-2008, 08:13 AM
ArmyRover's Avatar
Quoted: 37 Post(s)
Great minds think alike.
1972 MGB
716-898-8153
Want a
Need used parts?
post #10 of 16 (permalink) Old 11-16-2008, 04:10 PM
Quoted: 0 Post(s)
So I take a 96 Range Rover wouldn't be able to do it either.
trigga is offline
post #11 of 16 (permalink) Old 11-16-2008, 04:34 PM
roverich's Avatar
Quoted: 0 Post(s)
I think the other guys are saying its a brake issue . how old is that trailer , that it dosent have brakes . being 30 ft. long , you would think it would .
current vehicles : 96 Discovery-1 SE7. stock besides 255-70-r 16 ... SOLD
2000 Discovery-2 SD ...2 in OME 763 and 779 springs factory roof rail extensions , flat rack with 500ff's,hella 500's, .. new heads and head gasket . power steering pump , water pump . 265/75R16 guard dogs
roverich is offline
post #12 of 16 (permalink) Old 11-16-2008, 04:37 PM
ArmyRover's Avatar
Quoted: 37 Post(s)
A 96 Range Rover improves one of the drawbacks over a disco with the longer wheelbase 108" if I recall correctly. That's still an awful big load with no brakes on it.
It would be a better choice if it has the 4.6 in it.
Still not the greatest idea though.
And of course the early p38's have their own set of drawbacks
1972 MGB
716-898-8153
Want a
Need used parts?
post #13 of 16 (permalink) Old 11-17-2008, 09:14 AM
Quoted: 0 Post(s)
Its a 1997 travel trailer. From what the owner said and what I saw when i looking at it. It has its own receiver hitch type thing. Then the trailer hooks the the ball on that then on that same receiver there are 2 smaller balls that 2 bars from the trailer hooks on too. So basically there is one main big ball the 2 smaller balls that "stabilizer bars" hook to.
trigga is offline
post #14 of 16 (permalink) Old 11-17-2008, 09:17 AM
ArmyRover's Avatar
Quoted: 37 Post(s)
I would be really surprised if a 30 footer that new didn't have electric or surge brakes you might want to double check that. If it does than with a decent sway control set up you will be ok I would think in the end with towing that. I'd still go for a 3/4 truck though lol. There would be noithing worse then spending all that cash only to figure out you can't stand the set up.
1972 MGB
716-898-8153
Want a
Need used parts?
post #15 of 16 (permalink) Old 11-17-2008, 10:57 AM
Quoted: 0 Post(s)
I asked the owner if it was braked and they said no. I thought it to be on the big side too for no brakes.
trigga is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rovers Only General Forums > General Land Rover Discussion
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
You may post new threads
You may post replies
