Old 02-17-2008, 11:39 AM   #1 (permalink)
msggunny's Avatar
Gallery: 5
Default Who has successfully installed a radio in a Disco 1?
Seriously, i have searched and the general consensus seems that you have to gut or bypass the stock setup and run new wires for a successful radio set up.
Has anyone been able to use the stock set up with an aftermarket head unit?
Just deciding if i should quit wasting my time trying to get it to work and tear the sucker apart so i can rewire it.
Here is my problem:
I installed a new head unit and ran an OEM 2 interface that is supposed to allow the stereo to hook into the stock setup. It also has it running through the stock amp.
The radio works, but when i turn on the A/C, or run the wipers, you can hear the electrical interference coming through the speakers.
I have checked the ground that i have hooked into the radio, i can actually disconnect it and still hear the noise.
I do not have the rear factory subs hooked up yet though, could this be a problem?
Thanks.
77 SIII 88
97 D1 5 speed
91 D1 5 speed (the first, but gone )
the lord is my weapon
and i see him shoot pawns
woman is the devil
your god is a fraud
msggunny is offline   Reply With Quote
Old 02-17-2008, 03:07 PM   #2 (permalink)
XtremeMarine's Avatar
Gunny; if you're having electrical interference, hooking up the subs is not going to eliminate it. My guess would be that the ground is not a good connection, or you've got a power wire laying against a ground wire somewhere.
Originally Posted by Elemental
Some guys play hard to get, I play hard to want.
Old 02-17-2008, 05:25 PM   #3 (permalink)
Rebuilding Rover
ArmyRover's Avatar
I did it with a RRC factory system I know it's not the same but it took a lot of time.
rness.I had the interference problem also what it took was going and installing new grounds for the factory amps and then the problem was gone. Mine had the noise when it had a factory head unit as well though
http://snhlr.org/
91 Range Rover Classic
90 RRC Parts truck
94 Saab gas mileage beater
iPod hookup for factory radio in '04 Disco? autophiles Discovery Series II 7 11-30-2006 05:17 PM
Disco I Radio Antenna questions RobX4 Accessories 1 01-06-2006 11:46 PM
CD Radio for my 96 disco Eduardo Discovery Series I 0 08-21-2005 09:05 AM
Disco Radio CUZ2BME Discovery Series II 1 03-12-2005 04:02 AM
95 disco radio wiring diagram GentrysRover Discovery Series I 0 01-24-2005 05:22 PM
