Old 06-19-2006, 10:18 PM   #1 (permalink)
Majesticdisco1
disco12's Avatar
Default Will a 1 inch spacer help my "Disco Lean"
Even with the 2 inch lift the Disco is still leaning a tiny bit on the passenger side I notice this because my Disco looks like it has more lift on the Driver than on the Passenger. Will a 1 inch spacer help that so it can look even.
1996 D1
J "Crawler"
camo,33x10.50's
disco12 is online now   Reply With Quote
Old 06-19-2006, 11:55 PM   #2 (permalink)
Choqiees's Avatar
I am having the same problem, I guess 1 spacer on the pass. side should do the job. however, I don;t know whether it's gonna affect the handling or not. I measured from bottom to the fender and there's 1 inch difference in height.
this maybe the result of OME standart, before I put on my springs, I noticed the driver's side spring was slightly taller than pass. side and also the rear springs.
2002 Discovery II SE
1999 Range Rover P38 HSE
Old 06-20-2006, 07:39 AM   #3 (permalink)
Otherwise known as STEVE
I can't imagine why OME doesn't think that's a problem.
ONE INCH off? I'd send the springs back.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 06-20-2006, 09:37 AM   #4 (permalink)
The MoFab Man
-MOSES-'s Avatar
Try swapping them. Of course you shouldn't have to, but It will probably work.
http://www.MoFab.org
Are you gonna pass that ??
99' D1
55' S1 86" RHD SW
00' RR 4.6 HSE
My Favorites:
http://www.texasrovers.com/
http://pikespeakrovers.com/
http://oeminstock.com/
http://greatbasinrovers.com/
http://MyRover.net/
Yep, thats my truck in the avatar....
-MOSES- is offline   Reply With Quote
Old 06-20-2006, 11:01 AM   #5 (permalink)
You might want to get in touch with John Lee at Expedition Exchange, he sells a Rover Made spring isolator that is made to balance out the left to right lean. They are 1/2" and can be installed separatily or one on the top of the spring and one on the bottom, that is what I did to balance out my set of 751 springs.
They do not effect the handling of the truck or it's ride.
Old 06-20-2006, 11:24 AM   #6 (permalink)
Elephantitis penisitis
Disco12 - I think I have some...let me check....if so, you can get it when you pick up those tires....
Old 06-20-2006, 11:33 AM   #7 (permalink)
Wait...are we talking about this? If so, we already put thm on your truck. My thinking is that if we add spacers....it will lean the other way when you are in it. The reason why there is a lean is the difference in the springs to accomodate for driver load and so forth.
Old 06-20-2006, 11:57 AM   #8 (permalink)
Choqiees's Avatar
I also put 4 of those on top of each springs. I guess 210lb isn't enough to balnce the truck .
Old 06-20-2006, 05:43 PM   #9 (permalink)
rover carpenter
Angry lean is in the design
i think roverx hit the nail on the head. it sits perfect with a driver sitting in it. at least the classics do and i think discos too. regards , big jim... 90 classic and 95 classic. i just picked up the 95 a couple of weeks ago with the intention of selling the 90 classic. well, 2 days after the purchase of the 95, i got rearended in the 90 by some 16 year old with no license taking daddys minivan for a joyride. his ins. co. will probably total mine. hopefully i will get decent bucks on it. could be more than what i wouldve got if i sold it i will find out tomorrow when allstates adjuster finally makes it out to look at it.
BIG JIM is offline   Reply With Quote
Old 06-21-2006, 02:01 AM   #10 (permalink)
Majesticdisco1
disco12's Avatar
I guess I'll have to "lean back" (i got that from fat ass Joe) thanks for all the replies pals
1996 D1
J "Crawler"
camo,33x10.50's
