» Sponsors
» Sponsors
Old 08-31-2009, 01:45 PM   #1 (permalink)
RealRitzcracker's Avatar
Default Windshield Leak?!?!
Hey Guys!
I have a 2004 D2.
When it rains/ I wash my car.
Water leaks into the cabin.
The water is coming from the top center (Above Rear View Mirror) of the windshield.
I felt the space between the windshield and headliner.
I feel a piece along the entire top.
But the area just under the review mirror where it's attached to the roof.
Feels empty.
Not sure if that is right?
Do you think it's the seal outside?
Cause you can lift the top of it up.
Not sealed very good.
Same with the lower seal too.
I think my windshield wiper harness is corroded from a water leak there also.
Should I try to redo the outside seal?
Maybe add a new seal in the inside?
Is this a diy fix?
Thanks
RealRitzcracker is offline   Reply With Quote
Old 09-02-2009, 06:14 PM   #2 (permalink)
NEW GUY
JERSEY ROVER's Avatar
Its hard to say . Water is funny . It could be making on area wet but, be coming the car and trveling along a valley or seem no where close to where u see the leak. If you can I would pull the headliner down and have some one soak the car with a garden hose while you search for the the water is getting inside the car. When I work in the dealerships starting out as a mechanic I would take the whole interior out of a car when it had a water leak and put it under the shower while is sat in it with a flash light . Thats usually the easiest way to find it . If it is the whinsheild it gonna have to be re-sealed by a professional window installer
94 DISCO 1
www.discounttiredirect.com
JERSEY ROVER is offline   Reply With Quote
Old 09-10-2009, 04:45 AM   #3 (permalink)
HeadlinerExpress
HeadlinerExpress's Avatar
I agree with Jersey Rover!
Dont take any short cuts, Remove the Entire Headliner Board and water test the roof to locate the leak. Anything less than pulling the headliner Board is a waist of your time.
If you can not see the water leak with your own eyes its based on assumptions - Resolve your water issues using only facts - This will save you time & Money in the long run.
Typical Sunroof leaks on a discovery vary, I personally have never seen a bad Sunroof Seal between the Glass & The plastic Trim Ring. Most Leaks come from either a Bad Seal on the Front Windshield or a Outer Trim Ring warped with age that wont allow the Sunroof Glass to lay flush with the seal.
Go back to the websites search engine and type in Sunroof: Their you will find years of postings on this very subject with detailed instructions on how to resolve this problem.
Let me know if i can help in any way. Bill
Headliner Express
Headliner & Sunroof Repair
Winter Park, Florida USA
68 Unimog TLF-8 Firetruck
65 Unimog Radio Box
98 Range Rover 4.6
www.HeadlinerExpress.com
www.LandroverHeadliner.com
HeadlinerExpress is offline   Reply With Quote
Old 09-16-2009, 04:50 AM   #4 (permalink)
Its difficult to say.Just remove the headliner board and see from where it is leaking.
shainamathew21 LED Tail Lights
shainamathew21 is offline   Reply With Quote
Old 11-11-2009, 08:47 PM   #5 (permalink)
I know this post is old and you've probably found a solution by now, however, I just located my leak and it is indeed from where the a-post and the roof line are welded together. The only way I found it was by pulling away the weather strip around the door. It looks like the previous owner attempted to fix it with jb weld and failed. So, now i've located it, any ideas how to stop it?
2002 Land Rover Disco II
RoverX1325 is offline   Reply With Quote
Old 11-12-2009, 06:09 AM   #6 (permalink)
HeadlinerExpress
I would recommend If you can locate a (local Body Shop Supplier) Not a Body Shop! go to their store and tell the guys at the service counter what your dealing with and they will direct you to a product they sell to body shops to resolve your problem.
The Body Shop Suppliers Service desk Guys really know their Products and will answer any question you may have.
Heres a link in your area of 3 places to start.
Fredericksburg.com - Automobile Body Shop Equipment & Supplies in the Fredericksburg VA Area
Hope this helps in some way. Bill
Headliner Express
65 Unimog Radio Box
98 Range Rover 4.6
Old 11-12-2009, 06:18 AM   #7 (permalink)
Beta testing www.discogirl4x4.com
DiscoDream2's Avatar
Bill, you must have a bell on your computer that tells you a headliner issue is posted. You are all over these questions. Good job, thank you for the input!
1999 DII ~ ALPINE Edition
@>---^--- Discogirl4x4.com IS READY - COME VISIT! - Beta Version
Project DII:
New bumper cover w/trim, 2" lift, Bottorf Sliders, marker light, custom hood blackout, install DI CDL linkage, TW propshaft, diff guard-rear, mud plugs, Hi-Lift.
Completed
Head gaskets, synthetic oil, MAFS, coil pack, wires, alternator, tensioner pully, serp belt, PAS, fuel pump, 02/16" rims, 285/75/16 BFG KO, OE brush guard, wilderness roof rack, safari tail light guards, OE ladder, NATO fuel can, stereo upgrade, way cool oil gauge, Hella lights x6, CB radio, two rear trail/work lights.
DiscoDream2 is online now   Reply With Quote
Old 11-12-2009, 06:46 AM   #8 (permalink)
Deployed OIF
ArmyRover's Avatar
Bill is a very squared away guy, knows his stuff and is always there to help with a answer. If I was in Florida he'd be doing my headliner work.
of them." unknown quote.
(offending Austrailians since 2008)
http://www.wheelinrovers.com/
91 Range Rover Classic
89 Jaguar XJ6
Windshield leak? windsmith Discovery Series I 13 06-03-2009 06:32 PM
multiple coolant leak issues akabaa Discovery Series II 6 06-09-2008 09:44 PM
What's up with that rover oil leak thing??? Steph Discovery Series II 16 09-02-2007 11:37 PM
Windshield help!! Figman Discovery Series II 6 10-31-2005 09:17 AM
Headliner leak at windshield totallymann Discovery Series I 6 03-09-2005 05:29 PM
