It's partially a server-side setting, and partly a browser setting. On the server end, there's a setting to specify the duration of a session before auto-logoff, usually set to 2-8 hours. If you tell it to always remember you, though, you'll stay logged in until the cookie gets wiped by your browser.
HOWEVER, if you're experiencing rapid logoffs like that, make sure that your browser is set to accept all cookies from *.landroversonly.com, and that it's not deleting cookies when you close the browser, and the "Accept Only Session Cookies" setting isn't turned on. All of these could cause the problems people are seeing. Keeping you logged in is a combined effort between the server (making sure all sessions are accounted for) and your local browser (keeping the cookie intact so the server can read it whenever you show up).
