Links
Go Back   Land Rovers Only - Land Rover Forum > Land Rover Model Forums > Hybrid
Old 04-22-2007, 07:40 PM   #1 (permalink)
AZROVER's Avatar
Default DI Diesel Conversion
I just posted my basic idea for a diesel conversion in the General Discussion area. I probably should have posted my thoughts in this thread first since it seems there are some very knowledgeable people on the subject in the hybrid section. Any of you thoughts would be appreciated. Thanks!
-Hank
1998 Cobar Blue DI 4.0. OME 2" and custom AZ pinstripes.
AZROVER is offline   Reply With Quote
Old 04-23-2007, 02:34 PM   #2 (permalink)
Series Moderator
onslow's Avatar
-Hank
Cheapest option will be to source a 300Tdi and transmission will return 28-33 mpg more on a run and gentle,massive milage capability standard Landrover components,easily modified to give reliable extra power 160bhp it easily achievable.
Probably the best option would be to purchase a British lump and ship it a good 300 Tdi engine and trans with rad and intercooler should set you back around $3000 plus shipping
as US prices are nothing short of extortion
The td5 is another good option but you can double the initial purchase price.
If you need any further information just ask
I do have a contact who supplys good used 300 TDi engines and transmissions complete with rads and intercoolers all are tested and are generally low milage 70-100k units prices do vary for ultra low mileage units
Current fleet
86 90 V8 in bits
86 RR classic Under repair
94 Disco TDI 3dr ex-police 256k and still going
80" coil sprung V8 auto Trialer in progress
71 2a Trialer V8 auto,parabolics,6" shackles,power steering awesome machine
Stuff I have had at one time or another
76 S3 LWB
65 2a ex mil swb
71 2a swb safari
67 2a 1 tonne TACR
57 S1 V8 SWB
81 S3 SWB diesel
82 s3 SWB diesel
82 RR 2 dr perkins diesel
83 RR 4dr V8
84 RR 4dr V8 LPG
83 RR 4dr V8 LPG "in vogue"
88 RR gm 6.2 V8 Diesel
89 RR 3.5 mazda TDi
75 S3 LWB stationwagon
75 S3 2.6 LWB
86 110 2.5D
91 disco V8
91 disco TDi
89 disco V8
81 RR isuzu 2.8 TD
Old 04-23-2007, 03:50 PM   #3 (permalink)
The Best 4X4XFar
300bhp/ton's Avatar
-Hank
Ignoring the technical legalities of running a TDI in the US I also agree it would be the easiest option.
A 200 or 300TDI is an easy swap as they have no electronics to worry about (except a few latter 300Tdi's which had ECU's but I'd stay clear of them).
What tranny have you got at the moment and do you have air con (and do you want to keep it?)?
The TDI will bolt up to most of the recent tranny's (LT77 or R380 manual or the auto's) all you need is the correct bell housing. The transfer box should be the same.
I'd also recommend looking at getting a bigger intercooler it will make a difference. If you have air con the condensor will be in front of the rad this means you can't run a full width intercooler but high efficeny stock size ones are available. If you don't use the air con much I would consider getting rid of it so you can run a decent sized full width intercooler.
Have a look at Allisport, Jeremy J Fearn and Twisted Performance for ideas of performance mods (use Google to find them).
Apart from engine mounts and other minor accessories you should be set to pretty much drop it in and bolt it up (well kinda, but it should be pretty easy as far as engine swaps go).
200/300Tdi's are pretty available here, either 2nd hand or as a new/rebuilt engine. Only last year I bought a nice 200TDi from Ebay.co.uk for only £475 low milage and good condition. 300Tdi's are a bit more money, you generally see them for around £700-900. Or you could buy an entire vehicle just to get the engine out of it.
The TD5 is quite a different engine, well 5 cylinders for a start but it'll still fit the engine bay although might be a little tight in places. These are much more revvy engines but still very strong performers. They are fly-by-wire but that's not a major issue and of course have a ECU, but it's a pretty basic setup really. If you go this route you'll also need the ECU and probably the latter transfer box. There is also an in tank pump which you'll need to sort.
Prices are a tad more but surprising not that much more. I have seen TD5's go from £900-1100 range so still quite feasible. But it won't be a straight bolt in and will require a little more fab work.
This however would be worth it in my opinion, while the stock 122bhp (Defender - Discovery II TD5 had 136bhp) isn't all that impressive the engine does respond to mods very well. 190bhp is easy and Twisted Performance can supply bolt on's for 220bhp and well over 300lb ft torque and still have good MPG.
Remember numbers on diesels don't mean much, it's how they develop the power that counts, as in instant. Very very different to a V8 and IMO much much better in an off roader.
The Best 4X4XFar
Old 04-23-2007, 05:25 PM   #4 (permalink)
AZROVER's Avatar
Thanks for the replies guys. I just found out last night that there are about 10 300tdis with both 4 speed auto and 5 speed transmissions available just down the street from me in a warehouse. I can get it installed for a total of $6,000. How does this sound as far as the price? They are low mileage and it might be worth the extra $ to not worry about the shipping of one from across the pond. I am not sure if these are the ECU ones and I need to do a bit more research as far as legal ability of me to do this. As far as the A/C is concerned, I live in Phoenix so when its 110+ outside, it's kind of a matter of my health! What is the cost of a full length inter-cooler and the possibility of squeezing it in somewhere and still being able to use a/c? Thanks for the help!
-Hank
Old 04-23-2007, 06:31 PM   #5 (permalink)
96owner's Avatar
well for an intercooler just pull one off a supra or something there are tons of aftermarker stuff out there for rice burrners you can use and there is nothing more then i want then a TDI do 6,000 you say how long will this be offered and i dont cair for a/c
Delaware Mother******!
1996 Disco
Myspace
mods:
OME HD lift (thaks max)
zombie
96owner is offline   Reply With Quote
