» Sponsors
» Sponsors
Go Back   Land Rovers Only - Land Rover Forum > Land Rover Model Forums > Hybrid
Old 01-31-2005, 11:00 PM   #1 (permalink)
Default discovery series I with a series II engine
hey yall, have any of you tried or know of any modifications to put in a discovery series II engine into a discovery series I? is it even possible? also whats a good way to get 20-30 hp to make the series I engine 200+ hp?
DiscoDan is offline   Reply With Quote
Old 02-01-2005, 04:37 AM   #2 (permalink)
Disco's Avatar
Whats the point? Even if you had a spare series II engine lying around there would be very little to be gained by swapping over (except some headaches). If you are looking for added horsepower, that costs $$$$, depending on how far you want to go. The cheapest way to get around 100hp at the wheels, is to fit nitrous oxide, which is then available on demand (great for traffic light grand prix's). however, if you are only seeking 20-30hp you will need to do some tweaking. You could start by getting a chip upgrade (you would need some sort of an upgrade if you were to fit nitrous), headers, better ignition leads & perhaps coil/s. Forget about using fuel/octane additives, as these will only cost you money for no gain. You could also change your air filter, for that extra 1hp that I keep hearing about on different forums.
Hope this helps.
Old 02-04-2005, 03:46 AM   #3 (permalink)
You can fit a 4.6 l Range Rover engine. Front cover and distributor have to be changed plus a new ECU chip.
Ayidth is offline   Reply With Quote
Old 02-05-2005, 09:39 AM   #4 (permalink)
Searcaigh's Avatar
Gallery: 31
I thought most Rover V8s were interchangable
One of my friends has a 4.6 in his 130, another has just upgraded his RR from 4.0 to 4.6 and I am thinking of doing the same with one of my Discos when the engine gets tired however unless you upgrade the chip in the ECU its not going to make much difference
Gordon T. Smith
Middle East Land Rover Nutter
Searcaigh is offline   Reply With Quote
Old 02-05-2005, 02:57 PM   #5 (permalink)
Default engine swaps
Are you talking about the engine from a range rover classic?
Old 02-09-2005, 12:57 PM   #6 (permalink)
Banned
What year D1 do you have? GEMS?
All D1's can fit the 4.6 block. It's just a matter of swapping stuff over. It's not a big deal really. But, unless you can get a heck of a deal on a 4.6, it's not worth it. You can build a 3.9/4.0 for less money, and have more HP. Just as long as the cylinder walls are in good shape....
I have a 4.6L short block out of a 2003 D2, 7k miles, and a set of 4.6 heads, 7500 miles, that can be had.....
Hank is offline   Reply With Quote
Old 02-10-2005, 12:37 AM   #7 (permalink)
I got a 97 and what do you mean by GEMS?
Old 02-10-2005, 06:59 AM   #8 (permalink)
Banned
Weather it has a distributor....
Really, all you would need to do it swap over all the componets from the 4.0 (intake, brackets, mounts, etc...)to the 4.6 block. Without problems, and the right tools, you can have it done in a day/day and a half.
Still, just throw a cam, lifters, headers, high flow cats, flowmaster, and maybe a new HP chip, and you have the power equel to the 4.6, for a lot less money/time. And if you really want to get creative, remove the heads, have them shaved, ported, and pollished. I say 'maybe' on the HP chip, because there seems to be so many stories on power gains. Some really feel the difference, some feel no change....But, I have never installed a chip on a Land Rover, so I'm talking from my a** on that.
Old 02-13-2005, 10:29 AM   #9 (permalink)
TerryS's Avatar
Yes, you have a 4.0 GEMS engine (SAGEM ENGINE MANAGEMENT SYSTEM)
RPi engineering has been pretty successful with there chips (you have to do 2 chips, one is for fuel injector control, the other is for timing control) but you need to give them YOUR ECU, not one your body gave you, or one that came from the junkyard. It has to be done by them, they remove all the factory lockout BS and add their own scramble package. It costs pretty close to 700GBP ($1400 US) and they claims of 10-15% BHP increase, midrange torque increases, and fuel efficiency improvements, have been substantiated.
FWIW, if you go to a 4.6 engine from a P38 RR, pre 1999 1/2, it will also be Gems. If you go for an S2 Disco, or 4.6 from a post 1999 1/2 RR, it will be Bosch engine management. There are sensor differences, but thats about all. Don't even think of changing a Gems Car to Bosch (or vise versa, not that anyone would want to) as it would basically come down to rewiring just about the whole car. On a '97 with possibly 100k miles by now, it's a tossup which is the better route; changing the engine out to low miles 4.6, and the necessary ECU change for thecapacity increase, or rechipping your 4.0. Simply rechipping the 4.0, without some rebuilding to the valve train (cam, chain, lifters, regrinding & lapping the valves) will be a wasted effort. Doing both, and you won't care you don't have a 4.6.
The biggest improvement anyone can make to a Rover engine, is the least cost, but very labor intensive job of port matching your intake and exhaust.
TerryS is online now   Reply With Quote
Old 02-13-2005, 07:09 PM   #10 (permalink)
Disco's Avatar
You can drop in a 4.6 either GEMS or otherwise, but you will need a computer system a lot more sophisticated to piggyback your ECU than a couple of chips (Motec preferably), or, you can stroke your 4 litre out to 5.2 (4.7-4.8L is best), if you wish, however, either whichway, you are going to be up for big bucks.
Old 02-14-2005, 06:03 AM   #11 (permalink)
TerryS's Avatar
Disco, Explain what you mean by 'need to piggyback'. I have seen very little Motec use in the US. 5 or 6 years ago, It was generally considered a good (at least the M8) computer to replace Chevy (GM) systems, and I do know of a Rover application, but no one I know thouight they got any gain from it (except that the guy with the Rover needed a whole system and the Motec was cheaper) In all cases I know, it was used in place of, and not piggybacked.
As to GEMS 4.0 to GEMS 4.6 upgrade, It isn't even necessary to rechip the old GEMS computer, except that nothing will be gained. ONLY the fuel chip Has to be changed, but the timing maps SHOULD be changed. NO other ECU, piggybacked or otherwise is necessary.
HOLDEN may have improved with MOTEC, but SAGEM is far faster, adaptable, and (matter of opinion here) efficient. I always figured ROVER, by all their security "enhancements" were the only reason GEMS got a bad name, in the US. Outside of the US, I believe the securities, and lockouts are not used.
If it was my truck, and I was looking to upgrade from the 4.0 Gems to something else (I hope my friends would at least ask me why, I can't think of too many reasons in a 5000 lb truck) presumably a 4.6, I'd go the whole way and transplant the BOSCH loom and ECU.
Old 02-15-2005, 06:11 AM   #12 (permalink)
Disco's Avatar
As I run Motec in both my Discovery's I can assure you that they do allow a number of advantages with regards to fuel and ignition mapping, along with ignition control. By 'piggyback' I mean that the Motec takes over the major role of the OEM ECU, but does not control auxillary sensors such as ABS, SRS etc, although I have done away with the air flow sensor, as this is controlled by Motec also. Some of the other advantages of installing Motec is that with a laptop you can access and change characteristics in engine setup, tuning diagnostics, utilities etc, which I found to be an enormously useful and essential tool when fitted to my supercharged disco. When I put together my other discovery (91) with a 4.6, I originally decided to do it cheaper and fitted a Perfect Power engine management computer, well you know what they say "You only get what you pay for" so, as it had limitations, it had to go, and, I fitted a Motec to that also (no more hassles). To cut a long story short, one of my friends fitted a 4.6 to his 91 discovery, had a chip upgrade, and no end of trouble. By the time he managed to get it right, with lots of frustration and money, he wished he had done it the right way from the beginning.
BTW, you are correct that outside the US the securities and lockouts are not used.
Old 02-15-2005, 07:05 AM   #13 (permalink)
TerryS's Avatar
Only complaint I have heard re Motec by US users, was that it didn't work, out of the box, and 'customer' support' couldn't help via email. It meant staying up all night so they could phone the company, speak to a live voice, and VOILA, it worked. Guess it must be that the instructions were writen in Austrailian, and they only spoke American.
I didn't think the engine ECU handles ABS info, that's another wizbox, no?
I' d like to hear more about how you managed to rid yourself of the MAF. Which model Motec are you using? M800?
Whose chips did your friend use that gave the headaches? I have heard nothing but good about RPI, except, of coarse, the price.
Old 02-15-2005, 06:33 PM   #14 (permalink)
Disco's Avatar
Both my units are M48 Pro's. Here's how it works. air flow is controlled by the motec, via manifold pressure/vacuum, taking into account throttle position, rpm's and road speed.
FWIW, most of the Indy champ cars run Motec.
If you would like, I can attach photos of my setup.
Old 03-14-2005, 07:36 PM   #15 (permalink)
Discodan
I know that this is not the motor for you, but i have a td5 in my 94 disco
td5/v8
td5/v8 is offline   Reply With Quote
