Links
Go Back   Land Rovers Only - Land Rover Forum > Land Rover Model Forums > Hybrid
Old 04-28-2006, 04:39 PM   #1 (permalink)
Default Ethanol Anyone?
I guess this is the right forum, just checking to see if anyone has switched to 85% ethanol 15% gasoline, It looks like making the ethanol is pretty straight forward and depending on your choice molasses etc it can come down to about $1.00 a gallon. What do you reckon would need to be adjusted/changed for a LAnd Rover Discovery to run on that mix?
Disco1 is offline   Reply With Quote
Old 04-28-2006, 05:56 PM   #2 (permalink)
appstatedisco's Avatar
That's a good question. I was wondering that myself. I know GM made a large amount of it's cars e85 capable, wonder if LR intends on doing the same for petrol engines? I read that brazil is having alot of money pumped into it based on that fact of it's argicultural production of energy-producing crops.
AHO Rugby, a drinking club with a rugby problem.
www.ahorugby.net
"My experience through life has convinced me that, while moderation and temperance in all things are commendable and beneficial, abstinence from spirituous liquors is the best safeguard of morals and health."
- Robert E. Lee
appstatedisco is offline   Reply With Quote
Old 04-28-2006, 10:41 PM   #3 (permalink)
smileyq's Avatar
Wow 1.00 a gallon!! Thats like taking a step back in time. When does GM look to these vehicles on the road. Sounds great but it also seems like it would be a little harder to actually get gas because not every station would have it at first. How exciting though!!
"Good saddles ain't cheap, and cheap saddles ain't good."
smileyq is offline   Reply With Quote
Old 04-28-2006, 11:36 PM   #4 (permalink)
I read somewhere that GM has been making them for quite sometime. I think they're X million GM's out there that are e-85 capable, they've been doing it for a few years I think.
www.ahorugby.net
- Robert E. Lee
Old 04-28-2006, 11:39 PM   #5 (permalink)
http://www.gm.com/company/gmability/...e85/index.html
www.ahorugby.net
- Robert E. Lee
Old 04-28-2006, 11:56 PM   #6 (permalink)
smileyq's Avatar
Where can you get this gas? I know i heard that they already add it in in small amounts in the summer to prevent pricing from rising more than they already do or something.
Old 04-28-2006, 11:59 PM   #7 (permalink)
I believe GM has a list of states in which they have stations, and I would imagine they also have a list of those stations locations.
www.ahorugby.net
- Robert E. Lee
Old 04-29-2006, 05:59 PM   #8 (permalink)
LRDisco94's Avatar
Hey guys - just read that ethanol is going to cause more harm then good - im going to see if i can find the article so i can back myself up
-LRDisco94-
www.floridalandroverclub.com
LRDisco94 is offline   Reply With Quote
Old 04-29-2006, 06:35 PM   #9 (permalink)
smileyq's Avatar
Yea if you find that post it up here.
Old 05-01-2006, 01:44 PM   #10 (permalink)
He did what in his cup???
DevilDisco's Avatar
Last month's issue of popular mechanics had a large article on alternative fuels where it actually compared, the different types of alternative fuels in regards to milage, availabilty, wheater and their applications.
GM has a lot of ethanol vehicles out but I don't think there are too many sources. The article also showed that 1 gallon of ethanol has less range than 1 gallon of gas and 1 gallon of diesel far surpassed both gas and ethanol.
The 15% gas in ethanol is only supposed to keep the fuel from freezing, so these e85 cars are basically running on grain alcohol. The problem with a conversion to ethanol as I see it would be the seals. Alcohol is extremely good at degreasing things and does not mix will with rubber which a lot of seals are made out of. I dont' think it does too will with plastic either but silione will probably work well.
The best fuel as far as milage is concerned may be diesel or bio-diesel but in cold climates that could freeze and clog the fuel lines.
I think if you ran e-85 in a rover the engine or any gas car the effects migth not be too good..
'04 Discovery SE7. Last of the best.
DevilDisco is offline   Reply With Quote
Old 05-02-2006, 05:45 AM   #11 (permalink)
Found this article:
http://xcelplus.com/e85/article.htm
I guess one big disadvantage for Rovers using E85 is the amount of aluminum used in the engine and fuel system. I used to own a flexfuel Chevy S-10, and always wondered why the made the intake plenum out of plastic; its because of the highly corrosive nature of alcohol with aluminum.
O.B. is offline   Reply With Quote
Old 05-02-2006, 07:54 AM   #12 (permalink)
LRDisco94's Avatar
Well i cant seem to find that article now - it was posted on AOL it was on the scrolling highlights but it said that the emissions were bad something about VOC being higher - the production cost would be greater, like shipping wouldnt be able to put in oil lines because it absorbs water and could freeze in the winter - im still tryin to look for it
-LRDisco94-
Old 05-07-2006, 11:04 PM   #13 (permalink)
jnakoud's Avatar
check this out http://www.cbsnews.com/stories/2006/...n1588659.shtml
jnakoud is offline   Reply With Quote
Old 05-09-2006, 03:13 PM   #14 (permalink)
The Urban Motorist
Adam in NYC USA's Avatar
Cool Is ethanol the answer? Beware the BS (AOL Auto)
http://autos.aol.com/article/hybrid/...27121009990001
inert facts.
Old 05-10-2006, 01:08 PM   #15 (permalink)
Mostly Harmless
kellijo's Avatar
I have a local gas station who has an ethanol pump...Indiana. If one was only using their rover for local driving...this is such a great thing to have! You'd hate to be almost out of gas...and not be able to find a station for fill up. I'm curious to know myself...if it is actually possible for ethanol conversion in LR's? I've read this post...but if a person were to be very serious to do it...think it can happen? I'd consider it....
kellijo is offline   Reply With Quote
Old 05-11-2006, 04:57 AM   #16 (permalink)
LRDisco94's Avatar
Originally Posted by Adam in NYC USA
That the article i read - i couldnt find it - so your saying it is BS?
-LRDisco94-
Old 05-15-2006, 07:30 PM   #17 (permalink)
Default Below is a site on making your own biodiesel.
http://journeytoforever.org/biodiesel_make.html#1mixing
Wade
wade is offline   Reply With Quote
