» Sponsors
» Sponsors
Go Back   Land Rovers Only - Land Rover Forum > Land Rover Model Forums > Hybrid
Old 08-27-2004, 02:38 PM   #1 (permalink)
Default My Hybrid
Hi
looks like this is going to be a good site, i like the Hybrid section
my Landy is a S2 109 shortened to 100inc with a 90 front, then fitted to a Rangerover chassis 3.5 V8 pas etc, full arc cage fuel cell in the rear tub with battery, one of exhaust system exits through x member, pro comp +2 lift 33/12.5/15 mud's, buckets and harnesses and its nato green
Suggs (aka Harry Essex)
Suggs is offline   Reply With Quote
Old 08-27-2004, 04:05 PM   #2 (permalink)
heres a picy
Old 08-29-2004, 01:03 PM   #3 (permalink)
i saw it adevertised in aprils lro
Tommy McCuaig is offline   Reply With Quote
Old 08-29-2004, 01:40 PM   #4 (permalink)
Cool
are those wings square??!?!
challisc is offline   Reply With Quote
Old 08-29-2004, 10:11 PM   #5 (permalink)
Location: Live in Yattalunga, near Adelaide South Australia.
Default Tips on Hybrid - Where to start
I am contemplating building a Hybrid based on a Range Rover chassis - with Series 2 or 3 body. Whats the best approach? modify the chassis to fit Series Body or just add outriggers and cut down a 109 rear body?
Martin Hilton
Adelaide Australia
76 Series 3 Hardtop Ford 250 Automatic
89 Range Rover Vogue 4.2 (Vitesse Engine)
96 Discovery TDi Series 1 ES
99 Disovery TD5 Series 2 ACE/SLS
Yattalunga is offline   Reply With Quote
Old 08-30-2004, 03:32 AM   #6 (permalink)
yep may have been in LRO, i bought it from Ebay the seller was local so had a deal with him, can you remember what the price in LRO was????.
The wings have been cut away like a Lighweight to give max clearence, as for building a hybrid im not the man to advise you but i would rather cut the body than cut the chassis, in my opinion having a 100inch chassis with minimal body overhang seems to be one of the best type's off roaders like a Bobtail etc.
cheers
H
Old 08-30-2004, 04:28 AM   #7 (permalink)
Muttley's Avatar
Talking
What do you want to know? What do you want your hybrid to do? an off road toy? a racer? a workhorse? a posing mobile? as your answer will dictate the way you go about the build.
Hows this fer a hybrid!
Disaster Management Racing Scottish Hill Rally Photo Gallery 2004
YES it is a Landy, essentially it is a mid-engined range rover a very special landy, it's called a "SuggBugg" - the forerunner of the Simmbugghini. This is belived to be the ONLY surviving prototype of 6 built.
Not mine but I have the distinct pleasure of co-driving it on hill rallies here in the UK. (I'm the fat bstrd standing up with the neck brace).
If you need any advice about building a hybrid then give me a shout, I've just moved beyound the "contemplating stage" and am onto the start stage at the mo, though I am actually building a 90 defender out of a rangie - all will be revealed!
Muttley
Scottish Peasant
My landy is WAY faster than yours!
Muttley is offline   Reply With Quote
Old 09-14-2004, 06:13 AM   #8 (permalink)
Default Building a hybrid - mod the chassis or the tray?
Hi Again,
I want to build a bit of a toy for fooling around off road (mud/rock/sand) and on our hilly property (keeping cg low or else) with as much RR chassis/running gear as possible to get through local (South Australia) rechassis/rebody rules. I have a bit of rangie stuff lying around. I would prefer to add to a RR chassis rather than cut anything down. Looking at using a SI 107 or 109 open top ex army body but that depends on whether I can cut short or not. Looking for advice on what works/doesnt etc.
cheers,
Martin Hilton
Adelaide Australia
Old 09-14-2004, 06:17 AM   #9 (permalink)
Hi Suggs,
Any chance of you getting underneath sometime and taking a few photos of the firewall/outrigger mods, the rear member mod? looks like yours was done well - is the fuel tank like RR is is it a side tank?
Martin Hilton
Adelaide Australia
Old 09-19-2004, 11:36 AM   #10 (permalink)
Yattalunga
yep no problem mate ill do that, but the beast is in a workshop at the moment having some wireing sorted out, so when i get her back ill post some pic's for you, should be the end of the week
Cheers
H
Old 10-05-2004, 07:05 AM   #11 (permalink)
Default What A Beast!!!
lOOKS AWESOME. makes me want to use one of the old series 2 or 3 have in my w/shop to start a project. I even have 3.5 v8 out of a County although my Ford passion would have me use a windsor. Probably 302 and auto. MORE POWER!! OOOHHH YEEAH
Defender Man is offline   Reply With Quote
Old 10-10-2004, 06:04 AM   #12 (permalink)
Thanks
heres a pic after a recent off roading weekend
