Links
Go Back   Land Rovers Only - Land Rover Forum > Land Rover Model Forums > Hybrid
Old 09-10-2005, 01:08 AM   #1 (permalink)
Default Steering shaft
Can any one solve this problem?
I've got a lightweight on a coil sptung chassis with powersteering and 90/110 steering colum. But all the steering shafts I've looked at so far (range rover Defender) are to short I need one about 21 inches ?
Jones'y is offline   Reply With Quote
Old 12-08-2005, 05:08 AM   #2 (permalink)
Hi there
Whats the problem, if you are a competent weldor then just extend it.
I had to shorten mine when I fitted a custom non plastic dash.
all the best Roy
spectric is offline   Reply With Quote
Old 12-22-2005, 05:41 AM   #3 (permalink)
Originally Posted by spectric
Hi there
all the best Roy
Hello
I already have welded one fitted but a ministry inspector has deemed this unacceptable .
So I need to ether have one made or find one the correct length.
Old 01-20-2006, 12:07 AM   #4 (permalink)
Problem now sorted !
Managed to find a lower steering shaft with a longer middle section don't Know what land rover model it was from but with a longer Td5 bottom UJ fitted it added up to 20.5 inches .
So now the lightweight has a shiny new shaft replacing the welded one.
