#16 (permalink) |
Start off with 3 swb RRC, cut 2 in half to make trailer/camper unit which would haul extra gear, provide sleeping for 2 w/heat & a/c, inverter tankage, etc. here is a rough idead (I'm planning a classic not p38)
For the engine, the Yanmar Turbo Diesel, trans 6sp manual, power vac assisted brake system (off engine driven pump), engine driven air compressor, 4kw diesel genset/watermaker, etc. etc. etc. will post website with parts lists and details later, then document the build. ![]() |
#17 (permalink) | |
Profesional Hunter
Location: On the banks of the Great Grey-Green Greasy Limpopo River (Rudyard Kipling 1902)
In the 1980's Land Rover South Africa brought the SIII (Pickup & 10 seater) out with the Perkins 4236 as standerd factory spec. These were officially known as the R6. These landys are strong as a set of Oxen! although very slow (85km/h Max). They were also very noisy and quite heavy on Diesel. A mate of mine have a Pick up in this fromat and with some noise reduction materiel in the enjine bay and the cab managed to get the noise down. He also fitted Freeweel hubs and a Fairly Overdrive. Now he has a very good sucsessfull Landy. |
#18 (permalink) |
Moeras
Was that the series 3 stage 1 ? In Australia we had the 3.9 litre Isuzu diesel as a factory option from 1979 until the Defender was released here, it was a very popular option and considered by many owners here as the best Land Rover ever. The V8 was not nearly as popular, though there are a few around. I converted mine to run on waste vegetable oil, and have not had any problems in the last 2 years since I converted it. I recently bought a 1982 4door Range Rover and am presently in the process of replacing the V8 with a 3.6 litre Isuzu diesel I got the motor from a friend for $100 so it will be a very economical conversion, the 3.6 has 500 more RPM than the 3.9 diesel so hopefully it will suit the Range Rover even better than a 3.9, and because the Isuzu was a factory option over here, the conversion isn't as exotic as it may seem from other parts of the world. kind regards....Ron |
#19 (permalink) |
[quote=Curt]Anyone have info/experience or knowledge of putting a small marine diesel in a RR or Disco?
or have I had too much to drink ![]() I think the VM was originally a marine diesel and in my opinion VMs are absolutely excellent IF PROPERLY INSTALLED, INSTRUMENTED AND ALARMED. As fitted in Range Rovers they are not much good, but they are truly excellent in the Rover 825SD. Why is this? Well the 825 has a low water indicator, a temperature gauge that you can see even in the dark and an overheat light that blinks and is very attention grabbing. (my 825s overheating is due to missing, corroded away radiator fins and is being fixed). The 825 being transverse also doesn't have the problem of the water pump getting to be the highest thing when going up a steep hill. The Rangies viscous fan can also be a big problem and mine would be stiff when cold but freewheel when hot! Very bad news indeed. Fitting a solid fan from a 1973 Ford Granada was a great help as was a new radiator but alas the cooling system failed whilst hauling a heavy trailer up Chideock Hill on the A35. On the Rangie, once the water cooling fails the oil cooling also stops as the oil cooler is in the rad. (the 825 has a separate oil radiator similar to the Ford Scorpio VM and this seems a much better idea) Other Rangie snags are that the thermistor for the temperature gauge is in the water pipe to the radiator, and not in the cylinder head. Once the water and steam have gone, the temperature gauge begins to fall because this part is cooled by the fan. So you think things are getting better when they are actually getting worse . The end result is a knackered engine. 825s have the sensor in the head where it should be. The Scorpio has a north-south 2.5 VM and they are not noted for overheating but then they do have a big twin-fan high-tech alloy radiator. Possibly a Scorpio VM block (120BHP) could be adapted to suit a Range Rover. (the flywheel is different, as are a great many other details)Another good engine which is relatively inexpensive is the Rover Maestro/Montego turbo 2 litre (Perkins Prima in marine form) These give about 80BHP and being direct injection are very economical. The power is about twice that of early Landys and is OK. Best of all there is none of that infernal drive-by-wire stuff but there is regretably a timing belt. Good luck with your projects and best regards from Davey. |
#20 (permalink) |
I have a 110 with a perkins 236 and can drive 115-120 on flat and get 30 miles per gallon, Off road it is like an underdrive as it has loads of torque at less than 1000 rpm's. this is not the turbo version. Don't try to start at less than 0 deg without plugging in. I love this motor and am in the market for another. There are a few serious things that need to be done so make sure you shop for the right one. any help needed email newworld.timber@sympatico.ca
cheers Luke |
