Old 01-26-2006, 02:58 PM   #1 (permalink)
drum655's Avatar
Default 2 quick questions
1. How do i know if I have rotoflex or normal drive shafts? To me they look like normal ones but they may be rotoflex. what does a rotoflex look like? its an 01 DII by the way.
2. How the hell do i tell if i have the cdl nipple or not. where on the transfer case do i need to look? Pics would help tremendously!!!
2001 Disco II SE w/CDL
~Equipe 4x4 Winch Bumper
~Custom steel rear bumper
~Equipe 4x4 steering skid and radiator skid
~RTE rocksliders
~QT services front and rear diff guards
~2" RTE lift
~265/75 r16 Federal Couragia MTs
~Superwinch X9
~Safety Devices Roof Rack
drum655 is offline   Reply With Quote
Old 01-26-2006, 03:01 PM   #2 (permalink)
rmuller's Avatar
If you don't know... then you have the rotoflex.. its on the rear driveshaft at the back of it.. its a big rubber donut.
CDL nipple is on the top of the transfer case, there is a plate with 3 bolts in it, and either a big nut in the middle (you have it), or no nut. You have to reach up there and feel around.
Old 01-26-2006, 03:04 PM   #3 (permalink)
drum655's Avatar
so the rotoflex is just on the rear shaft? i looked and don't see this rubber donut you are talking about. can you put up a pic or something?
and the cdl nipple is in addition to those three nuts or is it one of the three nuts?
~RTE rocksliders
~2" RTE lift
~Superwinch X9
Old 01-26-2006, 03:21 PM   #4 (permalink)
drum655's Avatar
well i have the rotoflex but it looks ok. is there any way to tell visually if it is about to go bad?
and I HAVE the CDL nipple. that makes me happy. I need to buy one of those cdl kits? does the cdl really help that much on the trails?
~RTE rocksliders
~2" RTE lift
~Superwinch X9
Old 01-26-2006, 03:26 PM   #5 (permalink)
rmuller's Avatar
You sure you have the CDL nipple? most 2001's dont have it, only a few from the beginning of the year.. here is a pic of it:
If you have it, then YES you should find some way to activate it on the trails.. it'll probably be the most valuable mod you can do.
Old 01-26-2006, 03:35 PM   #6 (permalink)
drum655's Avatar
i am pretty sure i do...is the nipple on the front of the truck side of the transfer case. i felt up there and felt the three bolts and felt something in the middle! is there anyway to tell by my serial number when it was made to see if it was at the beginning of the year or not?
~RTE rocksliders
~2" RTE lift
~Superwinch X9
Old 01-26-2006, 03:39 PM   #7 (permalink)
rmuller's Avatar
Hey, if ya felt it, then thats awesome!
The VIN plate in your door (where the tire pressure is also) tells you when the truck was made.
Old 01-26-2006, 03:51 PM   #8 (permalink)
drum655's Avatar
when did they stop putting in the cdl nipple...do you know a date?
~RTE rocksliders
~2" RTE lift
~Superwinch X9
Old 01-26-2006, 03:53 PM   #9 (permalink)
drum655's Avatar
mine was made in march of 01...is that early enough
~RTE rocksliders
~2" RTE lift
~Superwinch X9
Old 01-26-2006, 04:11 PM   #10 (permalink)
rmuller's Avatar
Apparently so it seems, right? Mine was June '01, and I don't have it...
Old 01-26-2006, 04:19 PM   #11 (permalink)
drum655's Avatar
i am gonna try and hook up aboot leg ghetto rig like keptin i think!!!
~RTE rocksliders
~2" RTE lift
~Superwinch X9
Old 01-26-2006, 08:11 PM   #12 (permalink)
The guy with the Banhammer
keptin's Avatar
its the way to go....for $7 I can rip it out later if I get something better....for now it does the job brilliantly.
Josh Shapiro
DII
Old 01-26-2006, 09:19 PM   #13 (permalink)
To answer yur question as to whether the CDL really works, you had better believe it. You can, once you learn how, even turn off your traction control and ABS for even more fun off the road. Then you look at lockers and the list goes on.
Good luck and have fun.
Mike J.
Old 01-27-2006, 05:30 AM   #14 (permalink)
drum655's Avatar
turn off traction control? why would i want to do that? seems like it would help!
~RTE rocksliders
~2" RTE lift
~Superwinch X9
Old 01-27-2006, 06:49 AM   #15 (permalink)
Once you get out and get some hard miles under your belt, you will see that there are times when the traction control gets in the way. T/C is managed by the ABS system and there is nothing worse then having your brakes bouncing traction back and forth, sometimes where it is not needed. By turning it off, while having the cdl locked up you can keep an equal amount of traction front and rear instead of to maybe one wheel.
Like I say, once you get out and use it alot you will see what I mean.
Mike J.
