Old 02-15-2006, 08:15 AM   #1 (permalink)
texasrover's Avatar
Default After market Headlights...
Anyone try these aftermarket headlights? I see some advertised that are supposed to look HID and have anywhere from 6000k to 8000k color. The price is pretty low on those you see on Ebay but when you price Sylvania at the store (Silverstars) they are much higher and actually advertise less color.
I could use some new headlights... just curious. Any input or advise would be appreciated. I would like to have the brightest headlights I can because I drive in the country alot and many animals running across the road (deer...etc). I really dont want to run around with those blue headlights you see from time to time, though.
That is not a leak! That is undercarriage rust inhibitor.
98 Discovery
Old 02-15-2006, 09:17 AM   #2 (permalink)
02RhinoRange's Avatar
Location: Nashville,TN and Chattanooga/Dayton/Knoxville for play....
search and ye shall find....
Headlight Upgrades
I'm using 7000K bulbs for headlights with standard wattage.
Bulbs claim 90/100w output only using standard 50/55w draw.
I like mine, especially for the money, only $20 a pair.
My truck had these when I bought it, and I've only bought one other pair to replace a bulb that burnt out.
I bought mine here:
http://store.racinglab.com/nokarwhitpro6.html
And this to go with them to protect the wiring harness:
http://store.racinglab.com/kyoplheduwih4.html
I used these for the fogs, but I think I'm gonna go with yellow true fog bulbs next time:
http://store.racinglab.com/nokarwhitpro2.html
'02 Range Rover Rhino ed.
Warn XD9000 w/ factory winch tray
RockRover diff guard, RockRover sliders
Safety Devices roof rack
255/70R16 Pirelli Scorpion ATs on 16" DII alloys
255/55R18 Nitto 420S on 18" Proline wheels
'95 RRC LWB County
Coil conversion w/ OME shocks, AB springs
02RhinoRange is offline   Reply With Quote
Old 02-15-2006, 02:13 PM   #3 (permalink)
Otherwise known as STEVE
There's no light that will put out 90watts of light consuming 55 watts just because it's impossible. Light output is rated in lumens.
It's BS. Cheap eBay headlights are often overpowered blue tinted non-DOT illegal substandard junk.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 02-15-2006, 06:47 PM   #4 (permalink)
texasrover's Avatar
Nice to hear your opinion, do you have a suggestion? Are the Silverstars pretty good lights or do you recommend another?
98 Discovery
Old 02-15-2006, 07:35 PM   #5 (permalink)
I have Silverstars and they throw considerably more light than the stock stuff. I'm not at all unhappy with them.
I refuse to tip toe through Life only to arrive safely at Death
Rocks, Sand, Mud, Water whatever I just want to leave the pavement
Its your Life, LIVE it ENJOY it!
DiscoPilot is offline   Reply With Quote
Old 02-15-2006, 07:41 PM   #6 (permalink)
RageRover's Avatar
What kinda Rover you got DiscoPilot?
I've thought about getting Sylvania Silverstars for my RRC for a while. But I'd like to see more opinions about them first and if they're worth the buy.
1995 RRC LWB
-RTE 2" Lift Springs
-KMC Front Diff Guard
-T-Case out of an 92' RRC
Old 02-15-2006, 07:45 PM   #7 (permalink)
I have silverstars in mine- I lose one about every month or so... but it seems that both my 04 Discos burn out headlamp bulbs on a monthly basis regardless of brand.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 G4 Disco
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1973 SIII 88
Old 02-15-2006, 07:49 PM   #8 (permalink)
RageRover's Avatar
Do you take your rovers off-roading all the time? I'd think the bumps of the ruts would mess with the bulbs, but my RRC would use a whole headlight assembly for the Silverstars. Then again the pot holes around Michigan are probably worse. ....
1995 RRC LWB
Old 02-15-2006, 07:59 PM   #9 (permalink)
Jeez- convert to H4's on that Rangie and then you can swap just the bulbs instead of the whole thing.
One of my Discos never goes offroad- same problem with constant bulb changes as the offroad beastly one. Lots of our customers report the same problem.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 G4 Disco
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1973 SIII 88
Old 02-15-2006, 08:11 PM   #10 (permalink)
RageRover's Avatar
Wierd, and yeah I'll consider the H4 conversion, if I knew what it was. So, what is it? I know I'm asking like a dumbass. J/K
1995 RRC LWB
Old 02-15-2006, 08:28 PM   #11 (permalink)
Roads?...Where we're going, we don't need roads...
keptin's Avatar
I also run the silverstars....but I have never had a problem of bulbs burning out. I replaced my working stock bulbs for the silverstars a year ago....ive done some crazy $h!t since then that should have damaged the bulbs if it was going to....so jolting/bumps arnt the problem.
The silverstars seemed brighter, but im not sure if it was because they actually were, or because they are whiter. The whiter the light, the better it reflects, and in turn the more light is spread. On the flip side, for that same reason, whiter light is worse in snow, fog, etc. conditions vs. more yellow/amber light.
Josh Shapiro
DII
Photos at www.kep1.com
Old 02-15-2006, 08:47 PM   #12 (permalink)
RageRover's Avatar
Hmm...I still wonder. I'll have to wait on this later. I gotta get the essentials first, like tires, a lift kit, etc.. You know, the real stuff.
1995 RRC LWB
Old 02-16-2006, 12:23 PM   #13 (permalink)
I Have a D1 and don't have the frequent headlight burning problem... what are you doing to the rovers up there Steve?
My silverstars are whiter and brighter !
Old 02-16-2006, 09:28 PM   #14 (permalink)
No relation to Felix The Cat
FelixLockhart's Avatar
I have Silverstars, and I upgraded the headlight wiring to a relayed system. The bulbs themselves are great, but the relay conversion made them even better, they're considerably brighter than most other headlights available.
Felix J. Lockhart
1995 Land Rover Discovery (Series 1)
FelixLockhart is offline   Reply With Quote
