Old 07-02-2005, 01:41 AM   #1 (permalink)
appstatedisco's Avatar
Default air bags and brush guards
i have a media-low duty brush guard(i believe it's the manik one) for my disco I, i also have dual air-bags, when i go off-roading, if i hit a small tree or something w/ the brush guard(assuming it doesn't crumble on impact) will the air bags deploy?), if so, is there any way to disable the air bags temporarily(while off-roading)?. they are extreamly expensive to replace and install, so this would be a huge plus. Also, if there is, how do you do it(pictures would help) and is it safe to do repetatively. any input welcome/appreciated.
- AppStateDisco
AHO Rugby, a drinking club with a rugby problem.
www.ahorugby.net
"My experience through life has convinced me that, while moderation and temperance in all things are commendable and beneficial, abstinence from spirituous liquors is the best safeguard of morals and health."
- Robert E. Lee
appstatedisco is offline   Reply With Quote
Old 07-02-2005, 07:40 AM   #2 (permalink)
downunderdisco's Avatar
Default bull bar & air bags
I just put an ARB deluxe bar on my disco 1 with airbags. The attachment bars that run north to south have a section that is a concertina ,which in a smallish shunt should compress without setting of the airbags. In a large hit they compact fully and allow the force to transfer to the front of the car and thus the air bags deploy. I presume that would be the only section that may need replacing after a small shunt. Your set up may be the same.
downunderdisco is offline   Reply With Quote
Old 07-02-2005, 11:40 PM   #3 (permalink)
Super Moderator
Disco's Avatar
It's not a good idea to disable the airbags (it can be done easily), as they are there for you and your passengers protection. I accept that fitting new airbags is expensive, but how much is your life worth. What happens if you have a serious smash off-road and your airbags are disabled?
Old 07-03-2005, 12:22 AM   #4 (permalink)
i meant disabling them strictly for off-road use when speeds don't excede maybe 10 MPH and i'm not going to be doing rock-crawling or anything where i could flip down a mountain. Could you describe how to disable them, temporarily ofcourse, so i could enable after off-roading?
www.ahorugby.net
- Robert E. Lee
Old 07-05-2005, 02:07 PM   #5 (permalink)
can you describe how to disable the air bags temporarily just while off-roading?
www.ahorugby.net
- Robert E. Lee
Old 07-05-2005, 03:14 PM   #6 (permalink)
rmuller's Avatar
i wouldn't worry about it, i've never heard of a disco owner's airbags deploying while offroading.. just drive slow and avoid running head first into trees!
Old 07-05-2005, 05:48 PM   #7 (permalink)
rovering??
1st rover's Avatar
disco ,
dont the airbags only work if u are going over 30 mph?
-Nikunj
1993 Range Rover Classic LWB
1995 VW JETTA
1st rover is offline   Reply With Quote
Old 07-05-2005, 05:55 PM   #8 (permalink)
94 Defender 90
cellulararrest's Avatar
Originally Posted by 1st rover
disco ,
I think I heard that somewhere as well.
S.N.H.L.R.
cellulararrest is offline   Reply With Quote
Old 07-05-2005, 10:10 PM   #9 (permalink)
well if thats the case then thanks for the info, i wasn't aware they deployed at such a high mph. i def. won't be going that fast on any trail any time soon(or ever?)
www.ahorugby.net
- Robert E. Lee
