A quote on a head gaslet job can not really be known for sure unless yoou quote a really high number. By the time you pull the heads, send them out and have a machine shop inspected and repair them, valve job if needed, reinstall and replace hose, a serpentine belt and anything that was broken as part of doing the repair, you could be higher then that.
As far a dealer prices go, it is about normal but doesn't include head work if needed.
A lot of people use good, experienced small Rover shops, and there are some that do their own.
What ever you do, don't just get the gaskets replaced, have the heads inspected, at your mileage you can be getting near a valve job, don't put if off for a year when you can do it now and save a lot of labor.
Good luck, let us know what you do and what you pay.
