Old 02-02-2008, 06:08 AM   #1 (permalink)
discoII_td5's Avatar
Question Anybody know of an aftermarket outside temp guage
Hello does anybody know if LR does an aftermarket out side temp guage?
I have asked my usual part dealer in the UK (Rimmer bros Uk) and also the only one in Finland, they just offer me some cheap eyesore to stick on my dash.
Any suggestions greatly received
I have a Disco II TD5 on a 2000
Thank you
discoII_td5 is offline   Reply With Quote
Old 02-02-2008, 07:08 AM   #2 (permalink)
2004 Discovery II driver
go check out plx devices or autometer. they make some really high quality gauges both standard and computer modular that might be able to do what you need...but it'd be pricey no matter what.
stolenheron is offline   Reply With Quote
Old 02-02-2008, 12:33 PM   #3 (permalink)
2002 Discovery II SE
I just took a round (maybe 2 1/2" Diameter) thermometer gauge and bolted it to the mirror on one of my trucks. Works great.
Alak is online now   Reply With Quote
Old 02-03-2008, 11:31 AM   #4 (permalink)
teh rover newbie
79ROVERJP98's Avatar
Location: Endwell NY, where a rover would be great, lots of floods spring time
another tric tk i did with my old monty, is buy a temp gauge (electric one w/ a wire) and put the sessor on my roof, and the thing you read the tem on my mirror, liiked good and the wires could be hidden,
'79 land rover
79ROVERJP98 is offline   Reply With Quote
Old 02-03-2008, 11:33 AM   #5 (permalink)
duct tape and a thermometer will always work.
Old 02-03-2008, 02:24 PM   #6 (permalink)
Thats essentially what I did. I'll get a photo from work on monday. Its so simple its scary.
Old 02-04-2008, 07:41 AM   #7 (permalink)
ok thanks for the heads up on his one, I will consider the temp meter aproach, although I was kinda hoping to find an addon for the rearview mirror or something that doesn't clutter the dash too much, I already have the gps and the drive+play from Harmon.
thank you once again
Old 02-06-2008, 07:06 AM   #8 (permalink)
phantom phan's Avatar
Default Outside Temp Gauge
DiscoII
I thought it was standard on the TD5, sensor is in the door mirrors and readout via the climate control panel, if so it should be easy enough to retro fit using OEM parts from rimmers
regards
martin
G4 V8i ES Premium
Genuine Austrailian Event Vehicle
phantom phan is offline   Reply With Quote
Old 02-09-2008, 02:29 AM   #9 (permalink)
Thank you very much I will look in to this, to see if I can somehow use the signal to another gauge , as I only have the old manual heating controls, I do not want to upgrade the controller as i have heard that it would mean having to change quite a bit of the heater blower system
Thanks
Old 02-14-2008, 01:25 AM   #10 (permalink)
ok I found one not a perfect solution but saves having to have an extra clock on dash
2000 Land Rover Discovery Gentex Auto Rear View Mirror With Compass and Temperature
will let you know how I get on, thinking about digging deeper to findout whether or not I could hack this a bit and use the temp sensor in mirror
Old 02-14-2008, 10:35 PM   #11 (permalink)
Retriever
Cactusroy's Avatar
Talking
Td5 I have one that works great but it's expensive takes up the whole passenger seat it is voice activated and tells you when it's too cold out or to hot and when you are driving like an a33hole. I am willing to trade for a brush guard or a bag of really good chips.
"The world has gone to the dogs"
03 Disco SE
67 Mustang Convertible (Self Restored)
MB 500 SEL 85
Cactusroy is offline   Reply With Quote
Old 02-15-2008, 03:53 AM   #12 (permalink)
I think I have already a similar model to this, but mine is portable or rather it follows me around everywhere
90 RRC - temp guage not working rover1 Range Rover Classic 2 04-06-2006 06:59 AM
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 17 01-29-2006 01:18 PM
Wanted: water temp. sensor (guage) 87 RR Classic oldad Land Rover Parts and Vehicles Wanted 1 11-03-2005 07:29 PM
temp guage shot?!? Kevin88RRC Range Rover Classic 7 09-29-2005 08:51 AM
Temp Guage overheating jades007 Range Rover P38, Mk III and Range Rover Sport 1 02-27-2005 10:34 PM
