#16 (permalink) |
Yeah I couldn't imagine it'd be very difficult to install... i mean, it's drilling and bolting, thats not difficult.. The only thing I personally dont like is how far the frame is from the sill, and the rods you'll have to run to it... maybe a combination of sill & frame mounted will prevent any 'twisting' of the sills, but I've been happy with my sill mounted sliders.
#17 (permalink) | ||
Get in, hold on!
yeah, the actual frame is a long way off. actually what i did was use the body mount points. and my 1x2 1/4" wall goes inside the body mounts. so we achieved the same strength as going to the frame but without having to span the distance which would have required more supports. however in this case the strength of the frame vs sill mounted was needed.
-TsiArt ![]() 1989 Mercedes 190D 1985 Toyota 4Runner 1985 Subaru GL wagon |
#18 (permalink) |
I just saw this please dont get the ARB steps.. go with the RTE slider I can just see the step bend into your door. oowwwwwchhhh
Check out WWW.Lucky8LLc.com 716-898-8153 Justin |
#19 (permalink) |
96 Disco
I personally run a set of MOFAB sliders and love them, but I do not need them to act as a step. RTE's are rock solid, all i can say is the ones I have installed and seen on Discos take a hell of a beating, just touch up with a rattle can. Personally I havent seen any RTE's sliders give any problems at all. They actually incorporate an under belly slider also. Just my 2 cents worth.
#20 (permalink) |
remember the sill and frame do not move as one, there are rubber bushings under the body so don't connect the sill and the frame solidly.
RockWare makes frame mounted with rubber bumpers to the sill. Slickrock Fabrication makes some great sill mounts.
Todd Carpe Rangius Roverum |
#21 (permalink) |
Thor, you've brought up a point I had not thought about! I may just have MOFAB make me some with a step if the price is right. Otherwise, RTE is the way to go.
JC... 1996 Discovery SE - The Blue Marlin - gone =( 1965 Series IIa 109 RHD 2.25L Dsl - Wilks 1965 Series IIa 88' LHD 2.25L Petrol - Fionna |
#23 (permalink) | |
#24 (permalink) | ||
Get in, hold on!
#25 (permalink) | |
Rocky Mountain High
![]() Join Date: Sep 2005
Whatcha talking about???? LMAO!!! |
#26 (permalink) | ||
Get in, hold on!
#27 (permalink) |
good step, almost useless protection. On one trip we had to jack up one car using this step design, it bent so far you could not open the door while it was on the jack. In fairness it did go back again when off the jack again.
Jim
#28 (permalink) | |
Rocky Mountain High
#29 (permalink) | |
The design on the RTE is 2 L shaped pieces that are bolted together through the sill, so you actually get a double layer of steel on the bottom. Plus a very tight fit to the sill. Just follow the directions carefully.
#30 (permalink) | |
i have the type the wraps around the sill im very happy with them they take alot of abuse
