Old 06-24-2006, 08:28 PM   #1 (permalink)
01001010's Avatar
Gallery: 15
Arrow ARB Protection Steps
I'm considering purchasing a set of these. Anyone ever had any experience with them? Can they handle a good beating? Only reason why I'm not going the Rock-Slider/Nerf-Bar route is because I haul my parents areound a lot and they're always getting on my case about how tough it is to get into the truck (and that's just with slightly larger tires, imagine with the 2.5" Lift). I've seen these steps on many expedition vechiles. Here they are pictured on the famous DII Everyone sees in different catalogues...
JC...
Old 06-24-2006, 10:31 PM   #2 (permalink)
RageRover's Avatar
You and I got the same problem, the parent's.........about how high the truck is and with no running boards.
You have a link for where you found these? I can try to look around, but anyways, if they are thick enough in material (i.e. 3/16ths or thicker), made from steel, and how it's mounted to the body and/or frame, I would see no reason why they would get chewed up on the rocks.
1995 RRC LWB
-RTE 2" Lift Springs
-KMC Front Diff Guard
-T-Case out of an 92' RRC
Old 06-24-2006, 11:27 PM   #3 (permalink)
Ben
TN-LR3's Avatar
if you get a slider with a nerf bar like the rovertym they kindof act like a step into the car
1997 D-90 #1345- back to stock
2002 Dodge ram 2500CTD- dd/tow rig
looking to do 1 ton toyota or rover
TN-LR3 is offline   Reply With Quote
Old 06-24-2006, 11:34 PM   #4 (permalink)
RageRover's Avatar
Yeah they do act like a step, experienced this with Josh's (drum655) DII, his has nerfs and act like a good side step to get in the truck.
I wanna build sliders with nerfs, not only to make the parent's happy to better access the truck, but for better protection.
1995 RRC LWB
Old 06-25-2006, 01:25 AM   #5 (permalink)
Magicly Delicious
Bene's Avatar
I've seen more than one case where the step on a RTE slider has potected the doors from damage.
Kevin
1994 Discovery
Old 06-25-2006, 12:47 PM   #6 (permalink)
rmuller's Avatar
RTE sliders w/ nerf provide a very nice step to get up in the truck... plus it definitely does protect against body damage... learned that last week..
Old 06-25-2006, 01:06 PM   #7 (permalink)
I had them on my D2. I was always nervous about them but last off-road trip before I totalled it they got scraped and whacked several times and all it did was remove some paint. I'm not convinced they're as good as sliders (just put sliders on the D1 last weekend), but they're pretty tough. I got mine for same reason - parents. Worked good for them getting in and out too. I'd say a lot better than anything else out there step-wise.
jhmover is offline   Reply With Quote
Old 06-25-2006, 05:02 PM   #8 (permalink)
01001010's Avatar
Gallery: 15
Great! Thanks for the info guys! I think I'm definately going this route. Keep in mind that in South FLA the only boulders I need to worry about are the huge ones layed out infront of the entrances to places that are abandonded or on People's yards!..lol These ARB steps are frame mounted by the way, so they should definately be stirdy enough.
JC...
Old 06-25-2006, 05:19 PM   #9 (permalink)
RageRover's Avatar
Don't forget the boulders out by some of the Miami Beach docks and such. Those will be fun to wheel on.
1995 RRC LWB
Old 06-25-2006, 05:21 PM   #10 (permalink)
01001010's Avatar
Gallery: 15
LOLOL....truuue!....
JC...
Old 02-26-2007, 08:52 PM   #11 (permalink)
01001010's Avatar
Gallery: 15
Bump...
Still curious
JC...
Old 02-26-2007, 09:00 PM   #12 (permalink)
rmuller's Avatar
Eh I'd still go the slider route, especially if you're still considering moving north to Georgia, you'll be more likely to start running into rocks.
Old 02-26-2007, 09:03 PM   #13 (permalink)
01001010's Avatar
Gallery: 15
thats actually why I revisited the thread..lol...is one able to ask RTE to make additional frame mounts?
JC...
Old 02-26-2007, 09:06 PM   #14 (permalink)
rmuller's Avatar
Here check out this thread: http://muddyoval.com/forum/viewtopic.php?t=5063 ... we debated frame versus sill mounted.
Old 02-26-2007, 09:50 PM   #15 (permalink)
Get in, hold on!
toyota_jon's Avatar
i read through that. all i can say is i made a set of frame mounted sliders. and so far they've help up pretty well on rovertrains rig. and they don't take rocket science to install either. i used 4 grade 8 bolts on either side. it was a little bit of a PIA to drill the holes but, all in all took about 2 hrs to bolt them on.
I love Hillary Clinton saying " We all need to work hard for common good " I think Stalin said the same .
-TsiArt
The Garage-
1989 Mercedes 190D
1985 Toyota 4Runner
1985 Subaru GL wagon
toyota_jon is offline   Reply With Quote
