Old 02-26-2007, 09:51 PM   #16 (permalink)
rmuller's Avatar
Yeah I couldn't imagine it'd be very difficult to install... i mean, it's drilling and bolting, thats not difficult.. The only thing I personally dont like is how far the frame is from the sill, and the rods you'll have to run to it... maybe a combination of sill & frame mounted will prevent any 'twisting' of the sills, but I've been happy with my sill mounted sliders.
Old 02-26-2007, 10:15 PM   #17 (permalink)
Get in, hold on!
toyota_jon's Avatar
yeah, the actual frame is a long way off. actually what i did was use the body mount points. and my 1x2 1/4" wall goes inside the body mounts. so we achieved the same strength as going to the frame but without having to span the distance which would have required more supports. however in this case the strength of the frame vs sill mounted was needed.
I love Hillary Clinton saying " We all need to work hard for common good " I think Stalin said the same .
-TsiArt
The Garage-
1989 Mercedes 190D
1985 Toyota 4Runner
1985 Subaru GL wagon
toyota_jon is offline   Reply With Quote
Old 02-27-2007, 03:07 PM   #18 (permalink)
fivespddisco's Avatar
Gallery: 10
I just saw this please dont get the ARB steps.. go with the RTE slider I can just see the step bend into your door. oowwwwwchhhh
Check out WWW.Lucky8LLc.com 716-898-8153 Justin
fivespddisco is offline   Reply With Quote
Old 02-27-2007, 08:09 PM   #19 (permalink)
96 Disco
rovermech's Avatar
I personally run a set of MOFAB sliders and love them, but I do not need them to act as a step. RTE's are rock solid, all i can say is the ones I have installed and seen on Discos take a hell of a beating, just touch up with a rattle can. Personally I havent seen any RTE's sliders give any problems at all. They actually incorporate an under belly slider also. Just my 2 cents worth.
rovermech is offline   Reply With Quote
Old 02-27-2007, 09:00 PM   #20 (permalink)
Thor's Avatar
remember the sill and frame do not move as one, there are rubber bushings under the body so don't connect the sill and the frame solidly.
RockWare makes frame mounted with rubber bumpers to the sill.
Slickrock Fabrication makes some great sill mounts.
Todd
Carpe Rangius Roverum
Old 02-28-2007, 06:12 AM   #21 (permalink)
01001010's Avatar
Gallery: 15
Thor, you've brought up a point I had not thought about! I may just have MOFAB make me some with a step if the price is right. Otherwise, RTE is the way to go.
JC...
Old 02-28-2007, 05:31 PM   #22 (permalink)
You'd have to set it down pretty hard to bend the step into the door. I jacked one side up with a high lift one time using the ARB step.
jhmover is offline   Reply With Quote
Old 03-01-2007, 06:22 PM   #23 (permalink)
Gallery: 10
I respect your opinion But ...... they will not take a rock to the side or this see pic....
Old 03-01-2007, 09:32 PM   #24 (permalink)
Get in, hold on!
toyota_jon's Avatar
in your pic there did that disco have sill mounted sliders? and if so did they hold up to that drop? just curious i don't have a whole lot of faith in sill mounted sliders. i watched discodude and funrover bend theirs up. thats why when i built rovertrain his we went to frame. but also when our group goes out and wheels we don't see much mud, we see mostly rocks.
-TsiArt
The Garage-
1989 Mercedes 190D
1985 Toyota 4Runner
Old 03-01-2007, 09:36 PM   #25 (permalink)
Rocky Mountain High
Funrover's Avatar
Whatcha talking about???? LMAO!!!
Old 03-01-2007, 10:00 PM   #26 (permalink)
Get in, hold on!
toyota_jon's Avatar
i'm talking about holycross for you and for ryan well just about any other trail that has a rock thats 3ft big. lol
-TsiArt
The Garage-
1989 Mercedes 190D
1985 Toyota 4Runner
Old 03-01-2007, 10:14 PM   #27 (permalink)
salty's Avatar
good step, almost useless protection. On one trip we had to jack up one car using this step design, it bent so far you could not open the door while it was on the jack. In fairness it did go back again when off the jack again.
Jim
salty is offline   Reply With Quote
Old 03-02-2007, 07:15 AM   #28 (permalink)
Rocky Mountain High
Funrover's Avatar
Mine impressed me.......LOL...... The was about a 3 - 4ft drop onto a boulder...... Imagine if I didn't have sliders....OUCH!!
Old 03-02-2007, 02:16 PM   #29 (permalink)
Thor's Avatar
Good call. I used my RTE's on my 1995 to good effect on the Colorado rocks. I re-sprayed them a lot, but no bending.
The design on the RTE is 2 L shaped pieces that are bolted together through the sill, so you actually get a double layer of steel on the bottom. Plus a very tight fit to the sill. Just follow the directions carefully.
Todd
Old 03-02-2007, 04:41 PM   #30 (permalink)
Gallery: 10
i have the type the wraps around the sill im very happy with them they take alot of abuse
