Old 03-20-2008, 10:31 AM   #1 (permalink)
2002 Discovery II SE
Default ARB Winch Install Questions
Okay so Im ready to buy an ARB Bumper for my DII. I have a couple questions:
How does the winch mount to the bumper? See, I have a Warn XD9000i which has the built in stuff and its tall. When I originally breifly saw the bumper, I thought I'd just cut a hole in the top of the bumper so the winch sticks out.
Then I realized, what if it doesnt mount that way? Im screwed with a winch I can't use on a bumper I shouldn't have bought.
Alak is offline   Reply With Quote
Old 03-20-2008, 10:53 AM   #2 (permalink)
2004 Discovery II driver
why get an ARB bumper? there are better bumpers out there that will fit an XD9000i i'm sure. if you already have the winch, buy a bumper that fits the winch so you don't lose money.
stolenheron is offline   Reply With Quote
Old 03-20-2008, 12:23 PM   #3 (permalink)
Ian Matthews
p76rangie's Avatar
ARB bars fit Warn winches. Juts not high mounts..
Old 03-20-2008, 09:56 PM   #4 (permalink)
One of the concerns was airbag approval, which ARB is. The other choice I would have liked to buy is a little extreme and VERY Expensive to ship from england. Theres also the factory mount, which is badass I think. But in accual use, its a waste of money.
I just want to know if the bottom of the winch mounts to the front of the bumper or the bottom of the bumper.
Old 03-21-2008, 07:06 AM   #5 (permalink)
The winch will mount to the lower winch tray that is pre drilled.
Old 03-21-2008, 10:52 AM   #6 (permalink)
So, for example, if I mounted the XD9000i to it, it would sit properly and vertically.
This is good news as alls I have to do now is cut a wee hole in the top of the bumper.
Old 03-21-2008, 06:39 PM   #7 (permalink)
mudmonkey's Avatar
I don't think you'll have any problems...The "footplate" of the winch mounts against the front of the bumper, think of it as pushing your winch over backwards 90 deg. There's quiet abit of room behind the mounting plate. You will then undo the gearbox and rotate it back 90 deg so that you can reach the free pool handle, same with the motor for the connections... I didn't bother with either as the cables I fitted still reached the terminals plus I can't be arsed to free spool line out- that's why they have an out button on the remote.
Just don't bother fitting the bumpette's, I still need to post a picture of how they are produced but basically they are a bolt with a nail spot welded to it and molded into the rubber. Sneeze and the whole frigging ruber thing ends up on the drive way.
D2 with stuff added
mudmonkey is offline   Reply With Quote
Old 03-25-2008, 08:53 PM   #8 (permalink)
Just so were clear, I have this winch
found here Warn Industries - Premium Series: XD9000i
Old 03-26-2008, 06:53 PM   #9 (permalink)
mudmonkey's Avatar
I'll have to look again but I think there's plenty of room for you to rotate and install
D2 with stuff added
Old 03-28-2008, 09:27 AM   #10 (permalink)
My brother suggested buying a mount and using it for the back, then just buying another winch for the front.
He might be onto something.
I was also considering going with the factory mount for a little bit.
Old 03-31-2008, 08:39 AM   #11 (permalink)
XtremeMarine's Avatar
Back mounts which are removable usually, if not always mount to the receiver hitch. Not good for departure angles, accessibility in water/mud, or if you get stuck with your nose headed up in the air.
Questions re ARB Bull Bar & Winch install hermanpj Range Rover Classic 2 04-23-2007 01:46 PM
Comments/Suggestions [Post Here] rmuller Tech & DIY 29 04-20-2007 06:33 PM
Winch maintainence 02RhinoRange Accessories 13 12-07-2006 07:25 AM
New lights for Front bumper and winch edh Discovery Series I 2 08-26-2005 04:44 AM
WARN 8274-50 Winch, THE ULTIMATE!!! RedRhinoProducts Land Rover Parts and Accessories 0 09-28-2004 05:04 AM
