Old 09-20-2006, 12:11 PM   #1 (permalink)
Default Bumper & Winch
What bumper and winch combo is everyone using and how do you like it? Is there anything you would change?
Ex_MOD_110 is offline   Reply With Quote
Old 09-20-2006, 01:29 PM   #2 (permalink)
For what year and model truck? What sort of wheeling do you do, how much are you going to use the winch?
Old 09-20-2006, 06:06 PM   #3 (permalink)
A 1991 D110
Old 09-20-2006, 07:32 PM   #4 (permalink)
I can't help you there other then to say I would look at a 12,000# winch or more because of the weight and possible drag you will have when winching out of a problem.
Old 09-20-2006, 07:57 PM   #5 (permalink)
01001010's Avatar
Gallery: 15
Like mike has mentioned, there are different bumpers for different types of wheeling... Scorpion Racing / Equipe has low profile tube bumpers white ARBs petrude about 8 inches from the front of your truck, decreasing your approach angle. ARB's, however, have been designed, tested, and built to handle just about anything one can throw at it. Their manufacturing techniques surpass that of many other bumper makers (that I know of). They have their own indicator lights, mounts for addition lights, and a winch tray that can handle a heavy duty winch.
JC...
Old 09-21-2006, 11:48 PM   #6 (permalink)
salty's Avatar
For a winch I think 8 to 9k lb is plenty, use a snatch block with either to return the winch rope to the bumper and you have 16 to 18k of pull if you ever need it, I doubt this will be often.
Jim
salty is offline   Reply With Quote
Old 09-22-2006, 06:53 AM   #7 (permalink)
9000 or a 9,500 might work for a Disco but who wants to have only half the length of cable, cause you are using a block, and take over twice as long as your battery dies and the winch motor over heats, just to save a buck.
Old 09-22-2006, 10:39 AM   #8 (permalink)
I'd Rather Push a Landrover than Drive a Jeep
sevenrover's Avatar
Location: Durban, South Africa, 'til 2009. Then Back to Salt Lake.
Well, if you are in a situation where you need to winch more than 15 ft, you have bigger things to worry about. But as far as D110 bumpers go, I would go with ARB or Safari Gard, (even though it flexes under stress).
1991 RRC
2 1989 RRC's
1998 RR P38A
1967 SIIA 88
1969 SIIA 88
1967 SII 109
1971 Vampire Radio Body 101FC
sevenrover is offline   Reply With Quote
Old 09-24-2006, 05:07 AM   #9 (permalink)
If you are going to spend that sort of money for a Safari that flexes and bends, just get with a good welder and have him make you a bumper for your requirements that also looks good.
