Old 12-23-2007, 04:55 AM   #1 (permalink)
Default Disco 1 Trailer Electrics
I have a used Oris factory fit tow hitch which I want to fit to my 94 300tdi Disco. No trouble there but before I start hacking the loom apart does anyone know if there is a connection in the vehicles loom that I could just plug the 7 pin trailer socket straight into?
If there is one where should I start looking for it? Who, in the UK, stocks a connector that would mate up with it?
jimllshiftit is offline   Reply With Quote
Old 12-23-2007, 06:25 AM   #2 (permalink)
If your 994 Disco is like like our's, you might remove the r/r tail light assembly and look inside the panel, down towards the ground.
I can't tell you for sure where to buy a convertor for it in the UK other then from a dealer, but I know you can get good prices, on line from Atlantic Britis or Rover Connection. You should be able to find a more local on line site to buy from.
Good luck,
Old 12-24-2007, 07:07 AM   #3 (permalink)
Cheers Mike, that should give me a good excuse to spend Chrismas day in the workshop!!!!
All the best to you.
Should I buy a 97Disco or a Disco II? keroppi Discovery Series I 7 07-24-2008 08:47 PM
Trailer wiring Harness - HELP! One and All Accessories 6 02-19-2008 12:39 PM
Disco ll trailer wiring harness $60 Carlos Land Rover Parts and Accessories 0 12-04-2006 07:20 AM
97 Disco 1 DRL module location & trailer wiring? Dominic Discovery Series I 0 03-14-2006 09:33 PM
Pre-95 Disco Newbie needs more advice pfkb72 Discovery Series I 18 09-12-2005 09:49 AM
