Old 01-28-2006, 08:31 PM   #1 (permalink)
01001010's Avatar
Gallery: 15
Lightbulb Dual Alternators
GM has done this before on their workhorses. It's a great idea IMHO. Has anyone done, or seen it done in a Rover? I'm getting my winch soon so I'm looking into any option for power sources, from this crazy idea, to the average dual/triple battery set-up.
I posted this here since this idea doesnt apply to one specific truck and because it mainly has to do with powering up our accessories.
JC...
Old 01-28-2006, 08:43 PM   #2 (permalink)
RageRover's Avatar
Haven't seen a dual alternator setup for our Rovers yet, however I saw on "Monster Garage", they took an Escalade and ran a second alternator with additional bracket with all belt driven accesories still accounted for. If there is will ther is a way, and one person could custom fabricate something to make a second alternator fit under the hood of our Rovers. But I haven't yet seen a Rover with a second alternator.
1995 RRC LWB
-RTE 2" Lift Springs
-KMC Front Diff Guard
-T-Case out of an 92' RRC
Old 01-28-2006, 09:26 PM   #3 (permalink)
Magicly Delicious
Bene's Avatar
there's a first time for everything
Kevin
1994 Discovery
Old 01-28-2006, 09:36 PM   #4 (permalink)
Ian Matthews
p76rangie's Avatar
Sorry to tell you that it is a common mod for guys running 24 volt winches. They have one 12 volt alternator and one 24 volt alternator. You can get a dual pully for the aircon compressor and run it off of there.
Ian
Old 01-28-2006, 09:41 PM   #5 (permalink)
RageRover's Avatar
I did not know that. That 24 volt alternator would be pertect for the guy in the thread "Aircraft Landing Lights" to have for the lights he is using, which produce 600 watts of light, and requires 24 volts of juice.
1995 RRC LWB
Old 01-29-2006, 08:53 AM   #6 (permalink)
JC,
That is overkill for the average Rover with a winch. If you want the amps necessary to keep your winch happy, go to dual batterys, Between the normal alternator and the dual amps from a good set of dual batterys, you will have enough amps to run your winch on the hardest pulls and still keep tha winch motor cool.
I did this, it works for me and handles my HID lights, refrigerator and all the other crap I plug into my convertor.
Good luck,
Mike J.
Old 01-29-2006, 09:00 AM   #7 (permalink)
4x4 Adventure Gear
John C's Avatar
I went with a 200amp MG alt, haven't had any problems yet.
John C
1996 DI - 3" AG lift
1990 Kawasaki KL650B Tengai
1989 Kawasaki KLR650
Old 01-29-2006, 11:58 AM   #8 (permalink)
Actually a better setup for the winch wouldnt be a parallel series dual battery setup but an actual trailer accessory setup.
For example a trailer with a piston powered dump body uses a separate charging system with a line for charging from the trailer connector.
what you could do is use the same set up and use a deep cycle battery that way it charges the battery when it runs and doesnt need to be used as a starting battery.
Old 01-29-2006, 01:34 PM   #9 (permalink)
I think what you have suggested is good, but if your winch requires 450 amps at fuul load, one battery and alternator can't supply it all. That is why many people have heating problems while winching, not because of the load they are pulling but the shortage of available amps.
Just a thought,
Mike J.
Old 01-29-2006, 03:59 PM   #10 (permalink)
Ian Matthews
p76rangie's Avatar
24 volt winch motors tend to be more powerfull and quicker. Also the higher the voltage, the more energy you can fit down a given size power cable. You still need dual batteries for a 24 volt set-up, that is, 2 x 12 volt put in series. Most winch competition trucks now run 24 volt winches.
But this thread was about fitting dual alternators. The only reason 24 volts was mentioned was to state that it is a common reason for having a second alternator.
Ian
Old 01-29-2006, 05:43 PM   #11 (permalink)
TerryS's Avatar
A long while ago, I considered adding a second alternator on my 110. All that is necessary on any pre serpentine belt engine is to get hold of an aletrnator mount from an early Rangie where the alternator was mounted on the right side of the engine. It bolts to the same holes the AC compressor bracket bolts to. In my case, I had removed all the AC stuff so there it was, but as John says, a Mean Green alte will do everything two lame Bosch units will do, so why bother. If it's heavy winching you're concerned about, you are best served with two batteries.
Old 01-29-2006, 07:54 PM   #12 (permalink)
I have a Mean Green in the mail but i'm working on a 24 volt subsystem on the rover for welder, and possibly the aircraft lights, andanythign else I can come up with to run on 24V( like a badass winch ) Anyone have any links to a rover dual setup?
I refuse to tip toe through Life only to arrive safely at Death
Rocks, Sand, Mud, Water whatever I just want to leave the pavement
Its your Life, LIVE it ENJOY it!
DiscoPilot is offline   Reply With Quote
Old 02-06-2006, 11:44 AM   #13 (permalink)
AFIROVER
afirover's Avatar
I have a quad batery set up and love it
I am going duel alternators in the spring or when my shop is done
ac unit is bye-bye
we have used all four to start a truck on the trail once (the starter got to dame hot after a day of crawing around and would not start after lunch stuck all the bats on it and it started up )and for stuff like winching and welder and big sub box and lights ( 8 x100 watt driving lights go ahead "high beam me I dare you ) inverter ,elec fans and any thing eles i want
afirover is offline   Reply With Quote
Old 02-06-2006, 11:54 AM   #14 (permalink)
01001010's Avatar
Gallery: 15
Afirover,...NIIIIICE!!!!
JC...
Old 02-06-2006, 12:23 PM   #15 (permalink)
The Urban Motorist
Adam in NYC USA's Avatar
Lightbulb If you want to impress me,
make a double shaft, go to the alternator shop, get two and mount them on the same shaft back to back.
It will be awesome, even if it blows up.
Adam in NYC
inert facts.
