Elephantitis penisitis
Running a stock bumper...er...no bumper...cut to hell bumper...
what do you guys think would be the best thing to do for front recovery points? i don't particularly care for jate rings and have heard of them snapping during snatch movements (pun intended Griff). what about recovery hooks bolted to the frame where the bumper gets bolted to the frame? any other ideas?
Roads?...Where we're going, we don't need roads...
![]() Join Date: Oct 2005
This seems to be what you are talking about...they bolt to where the bumper would bolt up to......they are pictured on a TJM winch tray but you could connect to the frame.
https://www.expeditionexchange.com/curt/ $15/each ![]() |
Yup, them are it.
#4 (permalink) | |
Seeing that you are still an "amateur antagonist".... I took the money and went pro....
#6 (permalink) | |
Rover junkie
X, are you mounting your hooks at an angle like the ones in the pic? It seems that with hard pulls, there would be a lot of side load stress along the bolts. Kinda like forcing pressure on the bottom bolt upward and the upper bolt downward. I hope I explained that right.
Also, from what I understand, the grade 8 bolts aren't as strong side loaded like that compared to a grade 5. I could be wrong on that so, someone in the know, chime in.
Mike '98 disco with rte and 33's '07 jk rubicon.......pretty much stock Remembering A.Stevens #13739 Quote:
Correct about the bolts...if I did those types of hooks, I would also upgrade the bolts.
#9 (permalink) |
Get the strongest bolts that you can find... Have seen those things snapped off because of bolt failure, not fun. Even better in my opion is to have a certified welder put them on. That way you know that they are not going to come off without taking a large peice of the frame with it. Just my personal opion.
Andrew Barr. 1972 Series III 109. "the Tin Turtle" "However, that was his ploy and I caved....totally caved... LOL!" Jellijo
#10 (permalink) |
4x4 Adventure Gear
A few years ago I saw one of those hooks break off a 'burban. The guy had bolted it and welded it. What happended is when the weld gave way it also snapped the bolts. I would use just the bolts (upgraded ones) or just a good weld but never both.... you would think welded and bolted is better but it doesn't seem to be (in some cases).
John C 1996 DI - 3" AG lift 1995 DI - Scorpion Racing Extreme Kit 1991 RR - parting out (few parts left) 1990 Kawasaki KL650B Tengai 1989 Kawasaki KLR650 |
#11 (permalink) | |
You got PM Mike! I'm at home all weekend sick.
#12 (permalink) | |
#13 (permalink) | |
4x4 Adventure Gear
#14 (permalink) |
Oh certainly... that weld should not have given way like that. Bolts... hmmm why bother bolting and welding unless the weld was simple and not really structural... I have seen people spot weld some things in place for temp fixture but sound to me the penetration on that weld was bad. As for tempering that bolt... yep, sounds like that is exactly what happened.
That is not a leak! That is undercarriage rust inhibitor. 98 Discovery |
#15 (permalink) | |
