Old 02-04-2006, 11:04 PM   #16 (permalink)
Elephantitis penisitis
Originally Posted by rmuller
Actually, those are not mounted where the bumper would bolt up to.. you have to drill into the side of the winch tray to mount them.
Damnit...now I am back to square one...
Old 02-05-2006, 06:55 AM   #17 (permalink)
pickuprover's Avatar
The best recovery points that I have seen (still haven't gotten them on my series truck as my whole front bumper is a recoverypoint) is a thick metal plate welded to the face of the bumper at the horns then a large hole is drilled in it to allow a shackle to be attached. The shackle allows for a lot of diferent angles without binding. If anyone has been off-roading with the Nova Scotia club you probably have seen these. However since the plate is usually 1/4" thick you would need a welder capable of welding that thick of metal (usually only commercial units). Assuming though that you are running a rangie or a disco so that might look a little weird on the front of your truck, however they do look good on the flat series and defenders. Will try to find a photo of one of those.
Andrew Barr.
1972 Series III 109.
"the Tin Turtle"
"However, that was his ploy and I caved....totally caved... LOL!" Jellijo
pickuprover is offline   Reply With Quote
Old 02-05-2006, 12:05 PM   #18 (permalink)
Thanks Andrew! Yes, a photo would be appreciated.
