Old 01-25-2006, 08:40 PM   #1 (permalink)
RageRover's Avatar
Question Going up? Maybe...
I've been debating on the several questions about lifting a big truck like my RRC.
Instead of buying new springs is there something out there that you mount between the spring and the seat on either the axle or the upper seat for the spring that will give me lift? i.e a spacer, the same diameter as the spring.
(yeah it sounds like a stupid ass question but I had to ask it)
Another thing, if I get new springs, can I still use the shocks I got on there (cause the shocks are in good condition)? If not, why not?
Another question, can I do a body lift to my Rover which is an RRC? If so, is there a product out there I can buy or can I fabricate something?
I know these are some queer ass questions, but my roommates are a bunch of "Poop For Brains" knid of people. So I thought to ask the next best thing: you guys.
Any leading direction would be useful.
1995 RRC LWB
-RTE 2" Lift Springs
-KMC Front Diff Guard
-T-Case out of an 92' RRC
Old 01-25-2006, 09:09 PM   #2 (permalink)
RageRover's Avatar
Oh and another thing, should tires be a bigger issue than suspension parts as far as tire size?
1995 RRC LWB
Old 01-26-2006, 01:22 PM   #3 (permalink)
RageRover's Avatar
I might need a little help here, please.
1995 RRC LWB
Old 01-26-2006, 01:29 PM   #4 (permalink)
4x4 Adventure Gear
John C's Avatar
Spacers aren't recommended for stock springs. You can make your own spacers for about $40 (all four). I think the place is called Online Metals or something.
Body lift: Rovertym has them (I think around 200 bucks). I installed one and it was pretty easy, had to weld an extension to the steering shaft)
If you lift it you will have to make some shock extensions, which is easy to do.
John C
1996 DI - 3" AG lift
1990 Kawasaki KL650B Tengai
1989 Kawasaki KLR650
Old 01-26-2006, 02:08 PM   #5 (permalink)
Otherwise known as STEVE
I wouldn't bother with spacers unless trying to level an already modified truck to account for a winch/heavy bumper etc. I bought some on ebay that were nicer than any others I've seen and they were only $80 for all four, with hardware.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 01-26-2006, 04:05 PM   #6 (permalink)
Elephantitis penisitis
Yeah, I agree, stay away from spacers at this point.
I would recommend changing your shocks when you change your springs. You can use the same shocks if you replace with stock type springs. It seems to me that you are going to start doing mods so I would do new shocks at the same time.
As far as body lift goes...what is your reason for doing it? Usually people do it to accomodate a larger tire size, unless you are being a poser...
But seriously, do the springs and shocks, then go with a larger tire. Don't go too large on the tire otherwise you will run into other issues like gearing and so forth.
So how high do you want to go? When you hit 3" or higher, you will run into a whole host of other problems. Staying below 3" right now will suite you just fine. You could get away with running 265/75's with minimal trimming and only a slight decrease in power from take off and going up hill. In Lo range, you will not notice a decrease in power.
IMHO of course....
Old 01-26-2006, 09:29 PM   #7 (permalink)
RageRover's Avatar
Thanks for the input, I think I'll do the springs and the shocks, and worry about the body lift another time. I know where to go for new tires, Llesra mentioned some pretty good deals on this one site. Where could I get springs for cheap? I'm pretty sure where to get shocks but need to know where to get springs.
1995 RRC LWB
Old 01-26-2006, 09:35 PM   #8 (permalink)
Rocky Mountain High
Funrover's Avatar
Try the big blues fpom DAP....or go to rovertym
Old 01-26-2006, 09:39 PM   #9 (permalink)
Try the BB's from DAP. Combine them with OME shocks or Bilsteins. That should suite you fine and keep you within your budget.
Old 01-27-2006, 12:48 AM   #10 (permalink)
Magicly Delicious
Bene's Avatar
if money is an issue ProComp is a good way to go for shocks. i've had mine on for almost a year and they've taken a few hard hits and have held up quite well.
Kevin
1994 Discovery
Old 01-27-2006, 12:54 AM   #11 (permalink)
RageRover's Avatar
I'll give it shot, I think more importantly, I need to put some new rubber on those wheels first. I plan to remove the running boards to gain a little more clearance. Plus, wouldn't putting 225's vs. 205's on my wheels give me a little more lift? I wouldn't think by much, but I'm not sure.
1995 RRC LWB
Old 01-27-2006, 10:24 AM   #12 (permalink)
With the lift, you should be able to run 265's with little to no trimming on your rangie...
Old 01-27-2006, 10:34 AM   #13 (permalink)
Rocky Mountain High
Funrover's Avatar
I have a 2" lift and run 235 85 r 16..basicall 32" tires..no problems...
