Old 12-01-2005, 05:57 PM   #1 (permalink)
AAXD's Avatar
Gallery: 1
Default Headlight Upgrades
Has anyone used uprated headlight bulbs? I was thinking about getting a set of Sylvania silverstars. They claim to be much brighter than stock and anything is better than what I have right now. How can they be brighter if they are the same 45/65 wattage as stock? I just need something a little brighter for street use as I can't use my hellas around town. I got 100w H3's in my foglights which helps but is irritating to oncoming traffic. At $36 a set, any info is appreciated.
Thanks
Colin's Toys:
1972 Series III 88"
1997 Discovery XD
1983 Stage 1 109"
2002 Trek 4500
2005 Necky Looksha Sport
2007 Rans Rocket
2007 Honda Ruckus
Old 12-01-2005, 06:00 PM   #2 (permalink)
The guy with the Banhammer
keptin's Avatar
..double posted..
Josh Shapiro
DII
Old 12-01-2005, 06:01 PM   #3 (permalink)
keptin's Avatar
Ive got silverstars and I think that they are a bit brighter....definatly whiter so it seems much brighter because of the superior refraction of whiter light. They have also survived harsh trail jarring for 10 months. There are many more options for RRCs then DIIs though.
Search for it in a thread....there was a good one for RRC light options.
Josh Shapiro
DII
Old 12-01-2005, 06:09 PM   #4 (permalink)
Rover junkie
I've got the silverstars in my D1. Definately made a difference.
'98 disco with rte and 33's
'07 jk rubicon.......pretty much stock
Remembering A.Stevens #13739
Originally Posted by DallasRover
can't keep a good Rover Guy down.........unless there is a hot girl on top
Monty is offline   Reply With Quote
Old 12-01-2005, 06:12 PM   #5 (permalink)
01001010's Avatar
Gallery: 15
I've got PIAA Extreme White Plus bulbs on mine and they work like a charm!! I've got the stock D1 headlamps as well, which were slightly different to the Dii bezels, that help provide more light.
JC...
Old 12-01-2005, 06:21 PM   #6 (permalink)
No relation to Felix The Cat
FelixLockhart's Avatar
I have Silverstar bulbs in mine for now, and I installed relays on the headlights to allow them more power. When I convert to 4-bulb headlights this spring, I'll probably go to a true HID system
Felix J. Lockhart
1995 Land Rover Discovery (Series 1)
FelixLockhart is offline   Reply With Quote
Old 12-01-2005, 06:27 PM   #7 (permalink)
Choqiees's Avatar
hey did you also change the bulbs for the fog lights?
Old 12-01-2005, 06:40 PM   #8 (permalink)
01001010's Avatar
Gallery: 15
Nope, I didnt even touch my fog light since I cut my endcaps the day after I got my BrushBar, eliminating the use of the Fog Lights...BUT you CAN change the bulbs on the fog lights.
JC...
Old 12-01-2005, 06:48 PM   #9 (permalink)
Choqiees's Avatar
what kind of bulbs that the fog lights use? the manual does not say about the type. but it has that wire sticking out of the bulb.
Old 12-01-2005, 06:48 PM   #10 (permalink)
If you are interested, I have a pair of Wipac E-Code headlights with a pair of H-4 55/65 watt bulbs for auction on Ebay.
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMESE%3AIT
The lights were removed from a 1990 Range Rover and include the wiring adapters for the conversion. If you really want improvement install a relay, beef up the wiring and go with 55/100 watt bulbs. That is the setup I have been using for years. The only thing better that an E-Code headlights are HID's and they're going to cost you an awful lot more.
If you are interested, I am willing to end the auction early for the right price. Contact me directly at paulgrant@mac.com if you want more info.
Old 12-01-2005, 06:55 PM   #11 (permalink)
01001010's Avatar
Gallery: 15
You know man, now that you mention it, i dont think you can..lol..I just check...it did indeed not mention anything about the fog lights. I do remember seeing some sort of weird connection when I opened mine up. Soory about that mix up.
JC...
Old 12-01-2005, 06:57 PM   #12 (permalink)
Choqiees's Avatar
sniff....Thanks anyway
Old 12-01-2005, 07:05 PM   #13 (permalink)
I switched to Hella 80/100 and WOOOO are they good and bright. They are whire, not blue and after driving with them for 3 years in California, I have never had anyone flash at me while driving towards them. The high beams reall make a statement also. I didn't upgrade wiring or add relays and the wires run cool under that load.
Mike J.
Old 12-01-2005, 07:06 PM   #14 (permalink)
keptin's Avatar
hey guys.....I believe you are refering to D1 fog lamps....but you should check, I know you can replace the bulbs on DII stock fog lamps.
Josh Shapiro
DII
Old 12-01-2005, 08:21 PM   #15 (permalink)
Choqiees's Avatar
Keptin, mine's DII. I just checked the PIAA bulbs. they do have the bulbs with the wire (H3). looks similar with the stock one but I just don't want to bet $75 on it.
