Old 11-26-2005, 07:19 PM   #1 (permalink)
rutlanddisco's Avatar
Question Help! Mounting rock sliders
I need some help team. I have come to own some lightly used (no scratch or dent, just surface rust) Safari Guard rock sliders from my wonderful mechanic for a steal ($125). Safari guard's direction calls for a "rivnut gun" or something to that effect. Obviously I do not have that. Also there are a lot more holes on the sliders than on my truck. So my question is the best way to mount without gun? Do I drill holes to use them all? Or if anyone has done this themselves before I can use all the advice I can get and it would be greatly appreciated.
HELP!!!!!!!!!!
rutlanddisco is offline   Reply With Quote
Old 11-26-2005, 07:44 PM   #2 (permalink)
rivnuts sometimes require holes to be drilled but you can not use them. Its just a pain. And alot of time you have to use them or otherwise nothing will really stay put or you can get a nut behind it.
If you dont have one and more then likely a mechanic wont have one unless he installs alot of them I would suggest going to a body shop. They may actually have them and wont charge you too much to install some.
Old 11-26-2005, 08:34 PM   #3 (permalink)
When I removed my plastic trim from under the doors I believe there were 10 holes, so we just drilled them thru and used #8 grade 5/16th bolts to ancher to the frame, worked like a charm.
SG sliders can under hard use want to bend alittle so I would suggest you use a good heavy bolt for that extra support.
Mike J.
