Old 08-29-2006, 07:41 PM   #1 (permalink)
Default how long?
How long are the so-called 2" springs that are suppose to give extra 2" height to suspension? Someone said it was important to find out? Also, is the arm hanging down in the front of my 96 Disco the panhard rod? Can it be moved upwards away from the ground? Someone said there is suppose to be a kit to get these low hanging parts up off the ground? Thanks
Rebelman is offline   Reply With Quote
Old 08-29-2006, 07:45 PM   #2 (permalink)
Elephantitis penisitis
9"...oh wait...you're talking about springs.... depends on what brand you get... OME HD will give you 2"... RTE will give you 2.5-3"... as far as getting the low hanging stuff up...check out RTE... there is a link in my sig line...
Old 08-29-2006, 07:52 PM   #3 (permalink)
Thanks. I will have to contact RTE since I am not sure what it takes to make the change(drilling, cutting, hammer, etc.).
Old 08-29-2006, 07:56 PM   #4 (permalink)
Should be a straight swap...I have the RTE stuff on my truck (see sig line). Just make sure to get an alignment after you switch out the steering stuff.
Old 08-30-2006, 07:21 AM   #5 (permalink)
(9"s) , Now I know why you are using the avatar you use, told one too many fibbs.
Old 08-30-2006, 09:21 AM   #6 (permalink)
you need to talk to Kellijo...
Old 08-30-2006, 09:41 AM   #7 (permalink)
And what have you been up to, you been playing in the jello with her?
