Old 02-09-2007, 05:40 AM   #1 (permalink)
Offroader
DFW Rusty's Avatar
Default How is your winch wired?
I finally wired up my winch last night, and I am about 90% sure I did a pretty good job. I was just kinda wondering how everyone has there winches wired.
I went ahead and replaced the old top post ACDelco with an Optima red top, that has male top posts and female side posts. I used 2ga cables, I wired the ground directly to the battery, and I used a warn quick disconnect on the positive!
I am also a li'l bummed cuz my warn has some sheared gears, meaning I went ahead and bought my dad's Ramsey 8000 and will be using that junk till I can afford a 10k winch. I guess I will have to snatch block every time I winch!
'00 Disco II, custom built bumper, Voyager II roof rack.
'07 Jeep JK, 3" lift, custom bumper, winch, 35's
DFW Rusty is offline   Reply With Quote
Old 02-09-2007, 07:33 AM   #2 (permalink)
Otherwise known as STEVE
An 8K is probably more than adequate unless you're chassis deep in thick mud and have to break suction to extract it. The old "junk" ramsey 8K's are one of the longest lasting beater winches out there. After all- it still works and the Warn spewed gears...
I hope you didn't wire the winch to the side posts... they are not designed to meet the current draw of a winch.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 02-09-2007, 07:39 AM   #3 (permalink)
01001010's Avatar
Gallery: 15
Here ya go...
JC...
Old 02-09-2007, 08:11 AM   #4 (permalink)
Offroader
DFW Rusty's Avatar
uh...oh..... even if you put the screw in posts on it, that allow you to do clamps?
I may have to go home and fix that tonight! I am going to be doing a lot of creek driving this weekend!
Old 02-09-2007, 08:15 AM   #5 (permalink)
Offroader
DFW Rusty's Avatar
That is a really good point! The Warn was almost brand new, and the Ramsey is close to 5yrs old...... point proven! I guess I just have a chip on my shoulder because of my last experience with a ramsey!
Old 02-09-2007, 08:35 AM   #6 (permalink)
I have an 8 year old Ramsey on a beater truck- I abuse and neglect the winch and it always works.
Optima warns against using the side posts for huge current draw (like a winch). The winch will draw more power than the original vehicle would ever pull. I think they suggest putting the vehicle cables on the side terminals and the winch on the top terminals. I, of course, wouldn't recommend an Optima at all considering their failure rate.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 G4 Disco
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1973 SIII 88
Old 02-09-2007, 08:54 AM   #7 (permalink)
Offroader
DFW Rusty's Avatar
Thx Steve
Old 02-10-2007, 03:31 AM   #8 (permalink)
Ian Matthews
p76rangie's Avatar
JC, sure you got enough wire to that winch. By the time the power gets to the winch it would have forgotten what it was going there for.
How do you get to the solenoids if they play up?
Old 02-20-2007, 08:30 AM   #9 (permalink)
Put a jeep-had on you!!
LR Max's Avatar
DFW, is your warn less than 1 year old? If so, its still under warranty. Get it fixed and then sell it.
Otherwise you can probably sell some parts off of it. Is the motor still good? What model winch is it? I destroyed my motor in my warn so I am in the market for some used-but-not-terribly abused parts.
Super 109 Driver
Check out Crawl Magazine
www.crawlmag.com
LR Max is offline   Reply With Quote
Old 02-20-2007, 11:32 AM   #10 (permalink)
Menace2U's Avatar
Did you consider a deep-cycle (yellow or blue top) over the red top? Winching can drain a battery quick and deep cycles are meant to handle the charge/drain 'cycle'.
But you have a winch and I don't so you still win
AndrewT
Menace2U is offline   Reply With Quote
Old 02-20-2007, 12:52 PM   #11 (permalink)
01001010's Avatar
Gallery: 15
HAHAH!!..
Well, the snorkel hose comes off easy and the solenoid box is only held down by 2 screws I think. anything else is cake. I packed that thing with dielectric grease though.
JC...
Old 02-22-2007, 07:42 AM   #12 (permalink)
Offroader
DFW Rusty's Avatar
I will check on everything today, to see what exactly is wrong with the winch! I would gladly part it out, if someone needs the parts! I will let you know what I find out.
As far as waranty goes, I bought the winch used and the guy I bought it from never sent off for the factory waranty.... I called a local 4wl drive shop and they told me fat chance on getting warn to stand behind that winch without the paper work!
