yo mama
Anyone have a line on where to get these at the cheapest price??? eBay doesn't have any, unless you go to the UK site and the bloke with them will not ship outside the UK??????????
CHEERS!~! ![]()
ONE LIFE - LIVE IT |
I tell you for the money I just bought a couple of the hooks you find on the Surburban and such.
I too wanted JATE rings but thought the $50(US) each was a bit pricey. I put the hooks on for $2.38 in bolts (grade 8) and 30$ worth of hooks from a salvage yard. I have a class 3 hitch in the back so I don't need JATE rings back there. Ignore my busted links. http://www.okierover.com/recovery.htm Gotta up load those pics tonight. |
Jonesy,
I don't know what you call expensive but here is a source in ca at $45 each. https://www.expeditionexchange.com/kit/ |
rovering??
what about making them?
not very difficult.. just take a GI(galvanised iron)metal strip which is 1 inch wide and about 1/4 th inch thick. bend it into a U and drill holes on both the ends. then use a 4 inch long stainless steel bolt with lock nuts. wont this do?
-Nikunj 1993 Range Rover Classic LWB 1995 VW JETTA
rovering??
well here they are.
took me a total of 15 mins to make one. tools used my trusty dremel and a drill. and yes ill sell them for $10 each . Any one want them? The first picture is of jate ring that i found online for $ 45. and the other 2 are the ones i made. ![]()
#8 (permalink) | |
4x4 Adventure Gear
John C 1996 DI - 3" AG lift 1995 DI - Scorpion Racing Extreme Kit 1991 RR - parting out (few parts left) 1990 Kawasaki KL650B Tengai 1989 Kawasaki KLR650 |
#10 (permalink) | |
rovering??
but i came up with something better. and here it is. and it is rated at 14000 lbs... goes on to the rrc without drilling any holes and stays there securely. and sure is strong enough to tow the rrc out of trouble... ![]()
#11 (permalink) | |
Banned
Try a simple test here....Hook up your strap to that POS and tie it off to a tree. Start pulling. I bet you do not get to 1500rpm's before your exhaust clamp fails.. It's a u-bolt with a piece of tin foil. A grade 2 u-bolt at that. And what are you going to hook to that POS? There is not even enough room to get a winch hook in there. And, if your stuck in the mud, how the hell are you going to get in there to attach your strap or winch? You have got to be just joking.....No one in there right mind would EVER try this. For the amount of money you have spent on this junk, you could have purchased a nice receiver shackel mount by now. |
#12 (permalink) |
Banned
Jonsey,
First, get one of these If you think you still need JATE's, this place has them. Some nice bumper mount style recovery mounts can be had from this place, or from Dynaflex (but there site is down for some reason...www.dynaflexrecovery.com) Don't mess with the ideas that other nut has... |
#13 (permalink) |
yo mama
What a great thread - amazing what some folks dream of! Hey 1st Rover - DO NOT stand in front of your RR when you try to use those - they will bust off and come screaming through the air at superman speed and leave a bigger hole than you need in the cranium!Thanks for the try anyway but I think I will fork out the $45 and be done. CHEERS to HANK and 1stR!!! ![]()
