Old 10-21-2006, 01:38 PM   #1 (permalink)
LRDisco94's Avatar
Default Limb Risers
Well instead of mowing the lawn today...i installed limb risers
-LRDisco94-
www.floridalandroverclub.com
LRDisco94 is offline   Reply With Quote
Old 10-21-2006, 03:49 PM   #2 (permalink)
Where is my Black Son?
What is a Limb raiser? Don't believe i've heard that term before.
1996 Disco 1 SE7- Stock(Awesome sound system) DD/Range Rover hauler.
1990 RRC SWB Camel Trophy Inspired- ARB, Hella's, Bosch's, AR's 15X8, 32"MTR's,Equipe suspension stuff, Skids, waiting for more...
MuddyRangeRover is offline   Reply With Quote
Old 10-21-2006, 04:26 PM   #3 (permalink)
01001010's Avatar
Gallery: 15
a Limb Raiser is exaclty what its name says it to be....they raise tree limbs progressively so that your windshield doesnt get hit
JC...
Old 10-21-2006, 05:43 PM   #4 (permalink)
Rocky Mountain High
Funrover's Avatar
Welcome to the club..... I rock my homebuilt risers also!!
Old 10-21-2006, 08:59 PM   #5 (permalink)
got mud?
Jupiter Rover's Avatar
what do you need to install those? because ill love to put some on my rig.
PETE
DII
-- Pete
285/75 r16 Destination M/Ts
Old 10-21-2006, 09:04 PM   #6 (permalink)
Rocky Mountain High
Funrover's Avatar
PETE
about $15 and a trip to Home Depot......... You need 4 eyelets........cable, cable clamps... I will look for my post that tells how!
Old 10-21-2006, 09:16 PM   #7 (permalink)
Rocky Mountain High
Funrover's Avatar
Here is my link....
Now with Limb risers!!!
Here is another one...... This has the full rundown of how and what is needed!!!!!!
http://www.myrover.net/forums/viewth...id=682#pid5761
Here is an idea of the parts list...........
I chose to use the spring clips on the rack just to make it quick and easy to remonve them.
All peices are either stainless or aluminum.
All you will need is some wire cutters, a drill/bits, phillips head screwdriver, and a 7/16 wrench.
If you a frontend guard (I believe you do X) just pick your drill points, if not I have seen them in the hood at the corners (I was not wanting to drill my hood).
Then choose your roof mount points.
Here are the parts I used, I added a couple of other shots to help.
A: 1/8" Wire rope guides X 4 (Lowes # 102896). (I used these because I ended up with the coated wire, and they just made a better curve in the wire. Did not want a hole rubbed in the coating)
B: 5/16" Spring Snap Clips X 4 (Lowes# 103008)
C: LEHIGH #7316 Flush Type Clamps for 3/16" Wire Rope. These I got at Home Depot because Lowes did not have anything in stock.
D: 1/4" X 7 1/2" Stainchon (?) With eye hook on one end and a hook on the other end X 2 (Lowes # 90787).
E: 1/4" X 4 Stainless Eyebolts X 2 (Lowes # 31575)
Nylon Lock Washers
Washers
3/32" Coated Cable (I used about 15' @ 27 cents a linear foot)
Old 10-21-2006, 09:25 PM   #8 (permalink)
got mud?
REALLY thats it.. im doing this monday. and tuesday. ssweeet. your awesome bro thanks.
DII
-- Pete
Old 10-21-2006, 09:28 PM   #9 (permalink)
got mud?
so go to Lowes. and those are the part numberS? EX> /8" Wire rope guides X 4 (Lowes # 102896)
DII
-- Pete
Old 10-21-2006, 10:11 PM   #10 (permalink)
OoO, never knew they were called limb gurds. Heehe , looks nice!
Old 10-22-2006, 12:40 AM   #11 (permalink)
drewclare25's Avatar
think you could take a close up of how you mounted that with the oem brush guard?
Best 4x4xFar
97 Green D1
3" BB springs
pro comp es9000 shocks
32x11.50 BFG Mud Terrains
15" american racing steel wheels
flowmaster 40 series dual pipes
mantec snorkel
drewclare25 is offline   Reply With Quote
Old 10-22-2006, 09:24 AM   #12 (permalink)
LRDisco94's Avatar
Ok the limb risers were fairly simple to do, i spen $29 bucks at homedepot....
here some pics...i would of taken more...batteries died
Also..i did use clamps...i wrapped them in shrink wrap then a little electrical tape
Invest in some BOLT CUTTERS...took my 20min to cut the freakin wire...
Any questions feel free to ask...
-LRDisco94-
Old 10-22-2006, 09:31 AM   #13 (permalink)
Great job. As soon as I get a roof rack I'm getting some.
Old 10-22-2006, 09:36 AM   #14 (permalink)
LRDisco94's Avatar
The object of this setup is to get the limbs out of the way and Up and Over ur roof/lights/rack... so before u do any drilling go over ur setup
I also gooped up the holes i drilled and the bolts with Black sealant...i think i go overboard sometimes...idk..
O and make sure when u take ur measurements that ur adjuster has its bolts almost out of the adjuster..(hope tht makes sense) so when u get ur wire cut and all setup when u go to tighten ..it will actually be tight//if u cut ur wire and set it all up and u got to adjust and the bolts are in as far as they can go.. u have to recut ur wire
im gonna see if i can find my receipt
-LRDisco94-
Old 10-22-2006, 08:51 PM   #15 (permalink)
got mud?
sweet. it looks good
DII
-- Pete
