#241 (permalink) |
I see that CaptainRuss has posted within 3-minutes of one of my posts. I challange one of the Admin's to view the IP addresses for each of us. I would then like for the Admin to prove Ian wrong. Again.
CaptainRuss and Hank are not the same person, dumbass. |
#242 (permalink) | |
Support Our Troops
The Detroit Locker is an automatic locker that is always in operation. A Detroit locker works by leaving the diff locked and then it will automatically unlock when required. Basically they work by transmitting power equally to both wheels BUT allow a wheel to turn faster than the driven speed, such as required when cornering. A Detroit locker will allow one wheel to over speed, thus allowing easier cornering. So instead of "unlocking" and not transferring power to just one side it allows one of the wheels to spin faster while still providing power to both of the wheels. The ARB diff lock is operated by a switch when required and locks the diff completely. It does not allow any difference in wheel speed on the same axle. So when going around a turn on pavement a Detroit locker will provide power to both wheels, but it will allow the outside wheel to spin faster as needed. If your on dry smooth pavement this means no chirping. I am not an expert, but I believe the above should be pretty accurate.
John Conklin LRO Moderator |
#243 (permalink) | |
Support Our Troops
#244 (permalink) | |
Ian Matthews
Your only proof that I am wrong is that the person that relies on the cooking time of a tacho is right, so I must be wrong. The only thing that Hank has put up to prove he is right was ................ Wait a minute, he has NEVER put up anything to prove he was right. It has only ever been what he says happens. He has put up some photos of unrelated issues, but he has not put up ANYTHING to support his views on the DT, except that his tacho took too long to cook. But even then he offered no proof. Now let me see what I have put up, photos of a broken DT, admission by Hank that they break axles, Admissions by hank that often the DT destroys itself, detailed documentation from Eaton explaining how the DT works. I can see how you reckon that I have been proved wrong, the evidence provided to date really shows it. |
#245 (permalink) | |
Ian Matthews
#247 (permalink) |
jimfoo
Sorry, but not accurate. Without getting back into the argument, if the locker is locked, power to both wheels, both wheels have to turn at the same speed, so if it's locked on a corner, one tire is slipping. If one wheel is turning faster than the other on a corner, it has to be unlocked. There is no middle ground.
Jim Hall “That man has no respect for his Rover and beats the hell out of it every opportunity he gets, taking the most difficult line over each and every obstacle.” Michael 1966 88" 1.9l VW TDI, GT1749V, IC
#248 (permalink) | |
#250 (permalink) | |
Support Our Troops
Think of it this way................Now this is talking about being in 2 wheel drive.........One tire is on ice and the other is on solid ground.......with a Detroit locker the tire on solid ground will spin (because it has power to it) and the tire on the ice will ALSO SPIN only it will faster as there is nothing for it to grab traction on......Now if both tires are on solid ground and have traction then both will spin at the same time......Without the locker only the tire on the ice would spin because there would be no power to the wheel on solid ground. With a Detroit locker (which does not use spider gears) at least one wheel must turn the same rpm as the drive shaft while the other wheel can turn faster (but not slower). In most cases, the inboard wheel drives at the same RPM as the drive shaft and the outboard wheel unlocks and travels at the increased ground speed which is what is driving it.
#251 (permalink) | |
Ian Matthews
You are correct with the second example. That is, it is the contact with the ground that is driving the wheel faster and not the DT. |
#252 (permalink) |
Support Our Troops
OK maybe I misunderstood some things about lockers. Like I said before I am no expert. I am better with engines then with things like lockers.
#254 (permalink) |
This is just my understanding so correct me if I'm wrong. I don't have a detroit but have been learning about traction diffs.
The detroit behaves a lot differently in an AWD vehicle because both the front and rear axles are driving the truck. This halves the torque load going to the detroit making un-locking and locking less stressful compared to a part time/ rear wheel drive truck. The RWD truck goes from 50% on each rear shaft to 100% on one shaft when unlocking/ turning. I think this is the same reason that the detroit unlocks easier on an AWD truck; there is less power to the rear pinion because the front axle is receiving 50% of the torque (with CDL open). Torque or stress on the detroit will cause it to stay locked or re-lock, even on a smooth high traction surface while turning, but this is much more likely to happen in a rear wheel drive vehicle where the rear axle is seeing all of the torque. When the CDL is locked, torque can spike at the rear pinion if the front axle loses traction placing all the torque on the rear axle and keeping the detroit locked. Is that basically how it works? Dave |
#255 (permalink) | |
jimfoo
| Thread Tools | |
| Display Modes | |
| Diff Lock vs ARB locker | WineryRover | Accessories | 135 | 05-06-2006 10:06 PM |
| VC's, CDL's, and some locker stuff too! | nfrey2 | Range Rover Classic | 7 | 03-03-2006 06:47 PM |
| 1999 D1 Detroit Locker install | Discrover | Discovery Series I | 1 | 01-10-2006 04:20 PM |
| Rear Locker on '00 Discovery | ChicagoDon | Discovery Series I | 2 | 02-06-2005 12:48 PM |
| Are Disco II differentials open diffs & locker question? | RoverAsh | Discovery Series II | 9 | 12-14-2004 04:00 PM |
