#76 (permalink) | |
Ian Matthews
You state that when you drive through a corner, it is the front wheels driving. If this is so, then there would be no load to the rear. Therefore, under your theories, the diff will unlock as there is no load on it. You seem to be jumping around a little Hank. Are you getting a little confused also. Are you having difficulty determining what is real and what you have simply made up in your head? You need to lay down for a while and then go outside for a walk so you can work out what is real and what is not. |
#77 (permalink) |
P76,
So not the DT "locks"?????? It's always locked, moron. The DT is an "un-locker", really. When both wheels have 100% tractiuon, the locker is still locked. When one wheel looses traction, the locker is still locked. The ONLY time a DT is un-locked is where there is NO POWER TO THE PINION in a turn. Jim, You junk is broken. If you are on the gas in a turn, your locker is LOCKED. |
#79 (permalink) | |
Do you even have a Land Rover, Ian? There is no way someone can be as stupid as you. Your comments on a verity of Rover related topics are so far-fetched it really makes me wonder. |
#80 (permalink) | |
Ian Matthews
#81 (permalink) | |
#82 (permalink) |
jimfoo
Maybe Hank is right, sort of. Maybe whatever planet he lives on has every corner with a 10' radius. Under those circumstances, the built in wheel travel limit would be exceeded and the locker would lock. But here in the real world....
Hank, maybe you should put an ARB or spool in your truck, drive it on the road locked, then put a Detroit in. You WILL notice the difference.
Jim Hall “That man has no respect for his Rover and beats the hell out of it every opportunity he gets, taking the most difficult line over each and every obstacle.” Michael 1966 88" 1.9l VW TDI, GT1749V, IC
#83 (permalink) | |
Ian Matthews
I should stop making fun of you..... but it is too much fun |
#84 (permalink) | |
Ian Matthews
Loss of steering as the rear wheels attempt to push you in a straight line? Having the arse end of the car slide sideways on sideslopes? Unlocking when you want engine braking going down hills? Shock loading the diff and axles so that they break when you are out in the middle of nowhere? Forcing a wheel to break traction every time you turn into a corner on a dirt road? I have none of these issues with my ARB lockers. Now why would I want a detroit. Is it because you don't have to think about whether you need to switch it on or not. I can understand that you may not know when you will need the locker engaged, but the rest of us are not that stupid. |
#85 (permalink) | |
1- Unlock the t-case 2- Sometimes, but I never really had that problem enough to complain about it. 3- HUH?? See, this comment alone shows that you have no clue how the DT works. Why would the DT unlock going down a hill? 4- Quit running stock axles with a DT. The only time the DT's break, for the most part, is when a stock axle breaks first.The locker does not break first, the axle does. 5- Huh, so why would the wheel break traction? I thought they un-locked in a turn. Could it be because power is to the pinion? Even in a gravel parking lot, at low speeds, the DT will ratchet. If your locker locked mid-turn while you were acceleration, you just proved my point. No, you will not have these issues with an ARB. You will have, though, blown O-rings, pumps go bad, holes in air-line, blown fuses, lockers not unlocking in tight turns imeditily..... Don't get me wrong, I love my ARB's, but the DT/ARB set-up is pretty badass, too. |
#86 (permalink) | |
Now, go outside, get in you Series, and make some turns under power. You may only have a whopping 80HP, but you'll still get enough power to the pinion to show you the real deal. You can either do this and savor yourself the humiliation, or I will post real life video of this in action. Within 5-miles of me, I can gather video of a Series, D1, D2, RRC, and a Toyota will with DT's. It's a really simple test, guys. P76, Post some pics of your truck. I want to see this. |
#87 (permalink) | |
jimfoo
Well, enough of this thread for me. Time to work on the Rovers.
#88 (permalink) | |
got mud?
DII -- Pete 285/75 r16 Destination M/Ts |
#90 (permalink) |
got mud?
no.. you said you could get videos of your friends series, defender, disco I and DII.. so go do it.
| Thread Tools | |
| Display Modes | |
| Diff Lock vs ARB locker | WineryRover | Accessories | 135 | 05-06-2006 10:06 PM |
| VC's, CDL's, and some locker stuff too! | nfrey2 | Range Rover Classic | 7 | 03-03-2006 06:47 PM |
| 1999 D1 Detroit Locker install | Discrover | Discovery Series I | 1 | 01-10-2006 04:20 PM |
| Rear Locker on '00 Discovery | ChicagoDon | Discovery Series I | 2 | 02-06-2005 12:48 PM |
| Are Disco II differentials open diffs & locker question? | RoverAsh | Discovery Series II | 9 | 12-14-2004 04:00 PM |
