#121 (permalink) | |
Ian Matthews
My pump is located under the front passengers seat. It keeps it out of the heat and crap under the bonnet. This means that it lasts longer and I do not have any issue with the components fitted to it. In regard to who it is, or where it broke. You would not know the person or the area where it broke. How did it break, from shock loading when the axle disengaged and engaged. |
#123 (permalink) | |
So, tell me, Ian. 1) Who's DT is this? 2) How did it break? 3) Where did it break (location of wheeling area.) ......and, I'm still waiting on the pictures of your set-up |
#125 (permalink) | |||
Here is what I said, again for you to read. "With a open diff, the Pass side tire would never begin to turn. It's got way too much traction." SO if you think a truck can get up this ledge with no locker, take another hit of what ever you're smoking. Quote:
Showing pictures of your rock crawling mates does little to prove your point. You just look for an excuse to post pictures that you think are good. I already know that my dick is bigger than yours.[/quote] I'm still waiting on your pictures. From what I can tell, you do not even own a Rover. The pictures I've posted, both of my trucks and others, prove a point. I'm not posting them just to post them. You lact to prove anything except how big of a moron you are. |
#126 (permalink) | |
Ian Matthews
Would it make any difference if I told you it was John Smith's locker and it broke near cemetray hill. Now how many "O" rings are there? How long does it take to fix an air line? How do you drive home (or get back to a main road) when you blow up your DT. Come on, name the part in the ARB locker that when it fails leaves me any worse off that a stock vehicle. Explain to me how a wheel spinning under power and then suddenly getting traction is easier on axles than going slower and putting no shock load on the axle? How many people on this forum do competition rock crawling? So how relevant is your photos of climbing rocks to what people on this forum will use a locker for? You disappont me, I thought you were stupid enough to keep on debating points that you ended up proving to be wrong. |
#127 (permalink) | |
What will break in an ARB and leave you stuck? How about one of the 2 pinion pins? 1 of the 4 spider gears. What if the clutch gear breaks? Hell, if even a bolt snaps off it could jam the locker.... As far as how many peole here do competition rock crawing, I have no idea. That is why I recommend the DT/ARB set-up. Do you still not get that??? When I blew up my Detroit, I drove home!! LOL... Hell, I even drove around for another month with it busted! The entire thread about it is on Dweb if you think I'm making this up. Now, again: So, tell me, Ian. 1) Who's DT is this? 2) How did it break? 3) Where did it break (location of wheeling area.) ......and, I'm still waiting on the pictures of your set-up |
#128 (permalink) |
My head hurts.
P76 When a locker is locked it is forcing the wheels to spin at the same speed. That means they spin at the SAME SPEED. So if you dive you truck nice and slow up the hill on stock :crap: axles and one dose not want to spin at the same speed the axle will likely break. If you do the same in an open diff one of the tires will spin at different speeds. Either way stock axles are week. Can you post a pic of your truck? I would like to see where you put your ARB switchs. Mine are in the sun roof switch spot
Check out WWW.Lucky8LLc.com 716-898-8153 Justin |
#129 (permalink) | ||
Ian Matthews
And just to state you are wrong again, I have driven up similar rock faces with a locker and standard axles, and guess what, they did not break. But I cannot prove this, just like you cannot prove that standard axles would not have made it. Quote:
Still waiting for your answers ![]() ![]() |
#130 (permalink) | |
Ian Matthews
My switches are located on the centre console, just as it rises up to the arm rest. But I would not mount them here again. Too difficult to see if you accidently leave them on and also when on a steep hill things slide back on the console and sometimes switches the stupid things off. Yours sound a better location. All I need is a sunroof |
#131 (permalink) | |
What question have I not answered? Now, again: So, tell me, Ian. 1) Who's DT is this? 2) How did it break? 3) Where did it break (location of wheeling area.) ......and, I'm still waiting on the pictures of your set-up |
#132 (permalink) |
Do you really believe that? Will my 37s handle being locked and doing tight turn in the car park?
#133 (permalink) | |
Here is a good pic, again, of a place where lockers are required to make the climb, yet both rear tires are getting excelent traction: ![]() 9QUOTE]My switches are located on the centre console, just as it rises up to the arm rest. But I would not mount them here again. Too difficult to see if you accidently leave them on and also when on a steep hill things slide back on the console and sometimes switches the stupid things off. Yours sound a better location. All I need is a sunroof[/quote] I'm confused. Maybe a pictue will help. |
#134 (permalink) | |
Ian Matthews
How wide are your 37's, what type of rubber compound are they may of, what tyre pressure are you running, what diff ratios, etc. Running lower ratios than 3.54's is a big killer of axles in rovers. With 37's you are most likely running at least 4.11's, so you may run the risk of breaking axles. But then again I have had people drive home with 38 boggers and low ratio diffs locked and not broken anything. So to answer your question as best I can. You are certainly going to stress the axles doing what you suggested. But contrary to popular belief, rover axles are not made of tin foil. Whether you will stress them enough to break them, I do not know and nobody else will know unles they have actually done it. But my original point was, why would you have the locker engaged in such a situation in the first place. With an ARB you actually have a choice as to when to engage it. |
#135 (permalink) | |
Again, a lot of babbling here. For the record, many people have broken stock axles on 235/85/16 tires; both locked and not locked. Want pictures? There is even video on You Tube. |
| Thread Tools | |
| Display Modes | |
| Diff Lock vs ARB locker | WineryRover | Accessories | 135 | 05-06-2006 11:06 PM |
| VC's, CDL's, and some locker stuff too! | nfrey2 | Range Rover Classic | 7 | 03-03-2006 07:47 PM |
| 1999 D1 Detroit Locker install | Discrover | Discovery Series I | 1 | 01-10-2006 05:20 PM |
| Rear Locker on '00 Discovery | ChicagoDon | Discovery Series I | 2 | 02-06-2005 01:48 PM |
| Are Disco II differentials open diffs & locker question? | RoverAsh | Discovery Series II | 9 | 12-14-2004 05:00 PM |
