View Poll Results: Where should antenna be mounted?
Brush Guard 4 26.67%
Spare Tire 7 46.67%
Other 4 26.67%
Voters: 15. You may not vote on this poll
Old 02-12-2008, 01:44 PM   #1 (permalink)
LR123's Avatar
Default Mount CB Antenna on Brush Guard or Spare Tire?
Should I mount a 3' Firestik CB antenna on the brush guard or spare tire?
LR123 is offline   Reply With Quote
Old 02-12-2008, 03:23 PM   #2 (permalink)
Rocky Mountain High
Funrover's Avatar
For a freelander or Disco?
Old 02-12-2008, 03:28 PM   #3 (permalink)
LR123's Avatar
Oh my bad. Freelander.
Old 02-12-2008, 03:31 PM   #4 (permalink)
2002 Discovery II SE
I mounted mine on the inner fender between the fender and the bonnet. I can get a photo if you like. Looks like a factory antenna, only........not.
Alak is online now   Reply With Quote
Old 02-12-2008, 04:22 PM   #5 (permalink)
Rebuilding Rover
ArmyRover's Avatar
I'd mount it on the back but that is so it's not sticking up in front of my face.
http://snhlr.org/
91 Range Rover Classic
90 RRC Parts truck
94 Saab gas mileage beater
Old 02-12-2008, 06:05 PM   #6 (permalink)
2004 Discovery II driver
when/if i get a CB i'm mounting it on my rear spare tire mount. out of the way, easy to wire in through the rear door.
stolenheron is offline   Reply With Quote
Old 02-12-2008, 09:07 PM   #7 (permalink)
Rocky Mountain High
Funrover's Avatar
is there room on the spare tire mount?
Old 02-13-2008, 03:34 AM   #8 (permalink)
Roverhound's Avatar
Although I'm not a fan of the front mount attennas a 3' fire stick is to short to mount on the rear door. You need at least 2/3rd's of the anttenna to stick above the roof line for it to be effective.
Will this matter on the trail? Maybe not, depends on where you wheel.
Stick it on the bumper or get a longer anttenna.
It just doesn't matter.
Old 02-13-2008, 04:46 AM   #9 (permalink)
Ian Matthews
p76rangie's Avatar
The Firsetick requires a ground plane. So it really should not be mounted in either of the places you mention. At least on the front bar you will get half the plane that you need off the hood. Still mount be all that effective. Get a shorter antenna and mount it as close as possible to the centre of your roof. Use a ski bar and mount it as close to the roof as possible. Otherwise spend a little more money and get an antenna that doesn't require a ground plane.
p76rangie is online now   Reply With Quote
Old 02-13-2008, 07:01 AM   #10 (permalink)
deeker's Avatar
Gallery: 5
I mounted to the rear tire carrier on mine. It wasn't the perfect solution, obviously - but it worked better than I had expected. Decent reception on the highway, but bunched up in groups on trails there were no problems.
I ran the cable from the back door under the plastic on the side of the storage space, under the carpet beneath the rear seat up into the centre cubby bin between the front seats. I used a Cobra 75 WX/ST so it just had the little box to mount.
Current: 2004 G4 Discovery
Gone: Silver '02 Freelander SE
deeker is offline   Reply With Quote
Old 02-13-2008, 08:52 AM   #11 (permalink)
TerryS's Avatar
It's all about compromise when you're mounting a CB antenna on a trail rig.
As Ian says, the firestick, and actually all vertical antenna require a counterpoise (ground plane) beneath it, and the ideal situation, for omnidirectional capability, is directly in the center of a metal roof. For the obvious reasons, most people don't want it there. It often requires a hole in the roof, and leading in coax up inside the headliner. Even mounted to a roof bar, people don't want the antenna up there because of branches on the trail, garage doors, and lots of other reasons. Though not optimum, base loaded antennas work reasonably well on the front fender much better than on the rear spare mount, just because on the rear tire, it's so close to the body of the car, it significantly skews the radiation pattern. As long as the coil is above the hoodline when mounted on the brush bar, thats only marginally worse than the fender, but better than the rear tire mount.
Where ever it gets stuck, remember to grond the coax at the mount end also, either through the mount, or with a pigtail. Otherwise, the coax becomes an active element. All 'short' antennas, firesticks, based loaded coils, etc, are inferior to a true quarter wave, 110" whip ( a real tree whipper on a trail rig)
TerryS is online now   Reply With Quote
Old 02-14-2008, 01:03 AM   #12 (permalink)
Default cb
What really works good is use a magnet mount and put in the middle of the engine hood
ramwheel is offline   Reply With Quote
Old 09-01-2008, 11:39 PM   #13 (permalink)
CB Antennae, Antenna Mounts, GPS/GSM/AM/FM Multifunctional Antennae, GPS/GSM Antennae, TV/T-DMB Antennae, AM/FM Antennae, Dummy Antennae, Antenna Accessory, Connector, CB Radios, Antenna Manufacturer
Challenger communication equipment Co., Ltd. was formed in 2003 and over the past years have grown to be the Ningbo's leading manufacturer and exporter of Communication Antennae. We specialize in the design and manufacture of Antennae, Antenna Mounts, accessories etc.
Our workshop covers an area of 4000 square meters, and we are currently exporting almost 85% of our production. With well-equipped facilities and excellent quality control we have attained CE and ROSH certification for our production. Our experienced R&D team actively expands our product range to meet our customer’s demands and welcome OEM and ODM orders.
We have built up an efficient management system to provide you with our best service, with good quality parts , competitive price and short delivery, have been marketed into Europe, Middle East, North America and other areas.
More details please visit our website. Challenger communication Equipment Co., Ltd.
We are looking forward to make a good cooperation with you
Challenger communication equipment Co., Ltd. We specialize in the design and manufacture of Antennae, Antenna Mounts, accessories etc.
Http://www.acmeantenna.com
CB Radio
CB antenna
antenna mount
multifunctional antenna
GPS antenna
car antenna
TV antenna
FM/AM antenna
Dummy antenna
antenna accessory
antenna connector
acmeantenna is offline   Reply With Quote
Spare tire mount weight allowance Captainbarmonster Discovery Series II 9 05-10-2007 04:44 AM
Rear Spare Tire Carrier Ouestion karl von Series Land Rovers 3 07-19-2006 11:02 AM
Offset Spare Tire Mount bernardmann Discovery Series II 7 01-23-2006 01:52 PM
LR3 Tow plate, brush guard, and winch mount.... jzk Discovery 3 / LR3 0 02-16-2005 06:29 PM
Disco II Spare Tire Mount (larger tire) xtreme90 Discovery Series II 0 12-12-2004 11:22 AM
