Old 03-23-2007, 09:15 AM   #1 (permalink)
Default New Audio....
Hi Guys,
Just ordered a
Sony CDX-GT610Ui for my DISCO II for the iPod and USB port. Any tricks to removing the factory unit? and any idea, if there is a way I can keep my steering wheel radio controls?
Any comments would be appreciated.
Thanks,
Mark
Madison, WI
2000 DII
Mad_Rover is offline   Reply With Quote
Old 03-23-2007, 09:54 AM   #2 (permalink)
Mean and Green
Your new head unit likely comes with the required tools to remove the old one (just two small metal hooks that slide in the slits in the face). As for the steering wheel controls: http://www.crutchfield.com/S-66lBEA9...8900&I=127SWIX
werldcup is offline   Reply With Quote
Old 03-23-2007, 09:55 AM   #3 (permalink)
Mean and Green
Actually since you have a Sony... http://www.crutchfield.com/S-v3tob1j...900&I=127SWIPS
That one is plug and play(ish).
Old 03-23-2007, 10:53 AM   #4 (permalink)
rmuller's Avatar
As for the wiring of it, this may help:
Radio 12v | purple | + | radio harness
Radio Ground | black | - | radio harness
Radio Ignition | lt. green/purple | + | radio harness
Radio Illumination | red/brown (dimmer) | + | radio harness
Factory Amp Turn-on | same as power antenna wire
Power Antenna | red/blue | + | radio harness
LF Speaker +/- | black/white - black/brown | +,- | radio harness
RF Speaker +/- | black/pink - black/red | +,- | radio harness
LR Speaker +/- | black/yellow - black/orange | +,- | radio harness
RR Speaker +/- | black/green - black/blue | +,- | radio harness
[http://muddyoval.com/articles/disco2tech/DIIwiring.htm]
Old 03-23-2007, 11:02 AM   #5 (permalink)
Default Thanks Guys....That's very helpful!
I appreciate it...
Madison, WI
2000 DII
Old 03-28-2007, 10:43 AM   #6 (permalink)
Default Easiest audio install ever!
Got the Crutchfield VW wiring harness, Swapped the yellow and red wire. Removed the old radio. Plugged in the new unit and viola!
Sounds way better (and louder) then that factory Alpine did.
Just need a nice sunny day to tear apart the console to install the XM tuner and run the iPod controller.
Those wiring diagrams came in very handy..Thanks again.
Madison, WI
2000 DII
Old 03-30-2007, 06:35 AM   #7 (permalink)
Okay... might be a dumb question, but are the LR stock units (I have an '03 with Kenwood ..i think) a separate amp and unit? I've been considering replacing the unit for better iPod connection but haven't really pursued it because of the 12 or 13 speakers and amp thing. If it's that straightforward, I'll be heading out next week for a Sony unit like that.
BrianP is offline   Reply With Quote
Old 03-30-2007, 10:55 AM   #8 (permalink)
this is the wiring i used for my alpine cda 9857 http://www.shipsound.com/product_inf...ucts_id=101913
stevogabe is offline   Reply With Quote
Old 04-19-2007, 12:49 PM   #9 (permalink)
The amp is separate...At least on my '00 DII it is. There is a wire on the sony unit that will turn the amp on and off, with the headunit. and all the speaker wires from the headunit run to the Amp.
It was that easy...I used the wiring diagram provided above and corelated it to the Crutchfield/Sony Harness, plugged in the harness ...All of an hour.
and the rest of the system sounds amazing now...Don't think I'll be replacing the speakers either.
Madison, WI
2000 DII
Old 04-20-2007, 06:33 AM   #10 (permalink)
Thanks for this! Or maybe I should say "no thanks"...now I'm going to be running out to get the sony
Old 05-17-2008, 03:02 PM   #11 (permalink)
nzoliver's Avatar
Gallery: 5
Exclamation
Howdy!
I would check first!! I have had 2 DIIs and neither have been separate amped units. DIs yes, but not the DIIs. Use the ISO adapter and pluug staight in.
nzoliver is offline   Reply With Quote
