Oil Pressure Gauge and Adapter Plate - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 24 (permalink) Old 02-08-2010, 09:40 AM Thread Starter
DiscoDream2's Avatar
Quoted: 1 Post(s)
Oil Gauge ~ Adapter Plate
I have received a few inquires regarding the oil pressure gauge and adapter plate mentioned in a previous thread. A complete write-up is pending installation (when it gets warmer). Until then, here are the details about the gauge and adapter plate as requested.
Disclaimer: The original post / project by JYCSALAS at LRO. He has a complete write-up in this forum regarding the oil pressure gauge and a different method of installation and application. He made this recommendation to me and I am passing it along. Thanks Josh!
This FAQ will outline the adapter plate application versus his custom adapter. The oil filter shown is for demonstration purposes. Any filter will do and you may find you have a personal preference that will work as well.
FAQ
What is it?
This is an after-market oil gauge and adapter plate for installation and use.
Why would anyone want one of these?
To monitor the exact oil pressure at all times without having to rely on the OE warning light. It looks cool and can give peace of mind if you have a problem with oil pressure or fall into the problem VIN range.
Is it hard to install?
It is a basic project that will be compared to a basic oil change.
Where do I get the gauge and adapter?
Glowshift.com
GlowShift Performance Gauges & Gauge Pods - Automotive After Market Meters - Search
Part number for DII Adapter Plate - GS-AF2 3/4 UNF - 16 THREAD ADAPTER
Do I have to buy my gauge from the same place as the adapter?
No, you can purchase any electric oil pressure gauge that fits the application.
Is it expensive?
No, not compared to a failed engine as a result of low oil pressure.
Is it accurate?
Yes, if installed and used properly. Most importantly, it will perform better than the current way of monitoring pressure using a warning light.
Will it prevent engine failure?
No, but it will warn you of low or the lack of oil pressure so you can do something about it before it is too late.
Is the kit complete? Do I need to order anything else?
Each item is ordered separately based on desired gauge. You will need to have on hand some, electrical tape, soldering iron, wire caps or ends, red electrical wire and black grounding wire. Each of these items will depend on the desired installation location and type.
Do I need special tools or skills to install?
No, basic tools and skills will be enough to complete to installation if included instructions are followed.
Is there a clearance issue getting the filter on the adapter?
No, there is no interference with the filter after installation of a standard filter size.
I hope this answers many of your questions, If I can be of any assistance feel free to PM your questions. A complete writeup with installation photos will be completed soon and posted.
ID:	24298   Click image for larger version
ID:	24299   Click image for larger version
ID:	24300   Click image for larger version
DiscoDream2 is offline
post #2 of 24 (permalink) Old 02-08-2010, 11:30 AM
Rover-Holic and Admin
ArmyRover's Avatar
Quoted: 37 Post(s)
interesting way to go about it, but no matter what do not use a fram oil filter as pictured. They have been known to cause oil pressure issues on LR v8's.
1972 MGB
2007 Chawton White LR3
Trident Green, 1983 110
Need new parts, genuine Land Rover, aftermarket and off road upgrades, Support the Vendor that supports the Land Rover Community and Forum
716-898-8153
Have a DII you need a drive shaft click here
Want a
best read this first
Need used parts?
ArmyRover is offline
post #3 of 24 (permalink) Old 02-08-2010, 11:32 AM
mbrummal's Avatar
Quoted: 0 Post(s)
Yeah, I would get rid of the fram right now. I wouldn't even drive to the store to get a different filter. They are shitty filters for any vehicle.
This site sucks balls.
mbrummal is offline
post #4 of 24 (permalink) Old 02-08-2010, 11:53 AM Thread Starter
Quoted: 1 Post(s)
For sure, I picked it up at Walmart. I planned on running a couple oil changes through it before going synthetic, so I went cheap and then the snow came....I hear Napa has a good filter for our trucks.
post #5 of 24 (permalink) Old 02-08-2010, 12:03 PM
mbrummal's Avatar
Quoted: 0 Post(s)
get rid of it before it destroys your engine. It doesn't matter what oil you are using - a shitty filter like the fram is not the place to save money.
The napa gold filters are WIX which is a good filter.
mbrummal is offline
post #6 of 24 (permalink) Old 02-08-2010, 01:02 PM Thread Starter
Quoted: 1 Post(s)
Noted, will get one today.
post #7 of 24 (permalink) Old 02-08-2010, 02:58 PM
Quoted: 0 Post(s)
or use the mobil 1 extended filter.
03 Disco - Trail Rig
04 Disco - Expo Rig
06 ML 350 - Daily Driver
00 Boosted s2000 SCCA Racer - Weekend Racer
AxeAngel is offline
post #8 of 24 (permalink) Old 02-08-2010, 05:10 PM
antichrist's Avatar
Quoted: 3 Post(s)
Yeah, I agree, especially when you can do the same for a lot less using a "T" fitting.
Or WIX 51515 long filter for about 1/2 the price.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
74 Lightweight - The Antichrist (tag 6A666)
95 D1 - R380
95 D90 - R380
97 D1 - ZF
antichrist is offline
post #9 of 24 (permalink) Old 02-08-2010, 05:28 PM Thread Starter
Quoted: 1 Post(s)
Josh used the T fitting and it works well for him. I took the shortcut and used the adapter plate as an alternative way for those not T fitting inclined.
post #10 of 24 (permalink) Old 02-08-2010, 05:52 PM
antichrist's Avatar
Quoted: 3 Post(s)
How is spending 3 times as much money and a lot more work a "shortcut"?
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
97 D1 - ZF
post #11 of 24 (permalink) Old 02-08-2010, 06:25 PM Thread Starter
Quoted: 1 Post(s)
After seeing the fitting Josh made, it seemed to me easier and as cost effective as making the one he did. I don't have the supplies or a shop like some. So, pulling out the credit card was the shortcut. I have to change the filter and replace it sometime anyway so no time lost there and no need to remove the existing sensor for the oil light.
This adapter plate is one application that might work for some.
Here is the "T" fitting Josh made.
post #12 of 24 (permalink) Old 02-11-2010, 01:36 PM
Quoted: 0 Post(s)
I am the technical manager at FRAM. You are simply spreading misinformation. Our filters do not cause a drop in oil pressure, I would love to see your data that proves your statement. Our filters have much higher efficiency than WIX, ask them for results from ISO-4548-12 tests, we publish ours on the side of the box. If our filters destroyed engines as you claim, how could we stay in business for 75 years? Our filters are original equipment on Honda and Subaru automobiles and Mack trucks, the only truck with a million mile engine warranty.
motorking is offline
post #13 of 24 (permalink) Old 02-11-2010, 03:37 PM
mbrummal's Avatar
Quoted: 0 Post(s)
I would like to receive an official email from you (from a FRAM email account) saying the same thing before I will believe you are a technical manager at FRAM. PM me for my email address.
Where did I say it would drop the oil pressure? If anything, it would raise it!
I said they are a shitty filter because they have cardboard ends and cost a lot more than they should. Also, who's great idea was it to put an adative package in the high mileage filters?
I would much rather get a Wix filter with metal ends on the filter media than one of your filters. At least they have quality control. Better still, I can get 2 or 3 Wix filters for the price of one of yours.
mbrummal is offline
post #14 of 24 (permalink) Old 02-17-2010, 10:59 AM
antichrist's Avatar
Quoted: 3 Post(s)
In another thread I posted some information on gauge selection. It got deleted by the site admins when they did the restore, so I'll just post a link to another forum were I posted pretty much the same thing. This seems like an appropriate thread anyway.
My thoughts on gauge selection
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
97 D1 - ZF
post #15 of 24 (permalink) Old 02-17-2010, 12:15 PM
Quoted: 11 Post(s)
I don't see the advantage of the adapter plate when all that is required is a BSPP-NPT adapter, an NPT pressure switch and a pressure gauge.
Yes, I am still alive, and still in the Rover parts business.
Text me for greatest likelihood of finding me.
260-804-0458
Dominic Perodeau/Global British is a thieving bastard, do not send him money.
PTSchram is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rovers Only General Forums > Accessories
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
Installed Oil pressure gauge in my 2003 Disco jycsalas Discovery Series II 12 03-20-2009 01:07 PM
Oil Pressure Gauge SAM3 Discovery Series II 4 01-21-2009 11:02 AM
Oil Pressure Gauge 01001010 Accessories 2 03-01-2007 12:13 PM
Fitting an oil pressure gauge to 200tdi alan90def Defender 4 12-11-2005 01:17 AM
Temperature gauge adapter. RPGreg2600 Series Land Rovers 0 10-14-2005 03:07 PM
You may post new threads
You may post replies
