My question is should I by the medium or heavy duty OME springs? And depending on the answer, which shocks soft or firm.
Details: 03 D2 SE currently stock. Gearing up for off-road, which will be 1 maybe 2 weekends a month with guys that go for more than pre-cut trails. Definitely want to get at least a brush guard but may go with off-road bumper (no winch) with brush guard. Also want Rock Sliders, front to back skid plates, and I'll have the SD Roof Rack. With the lift, the tires will likely be 245/75-16 or 265/75-16. I can see bringing 100+ lbs of support gear and have put 400-500 lbs of material for construction or landscaping in the back of my previous truck. Would still like a "half way decent" (smooth??) ride on-road, so I'd like to know what to expect. I know this is probably the millionth posting with a question about suspensions, but I am asking specific to OME as at least that I have decided. |
You should stick with either the 779 or 751 HD front springs and the 762 rear HD springs along with only the OME H.D. shocks for the type of wheeling you may be doing and the weight you will be carring.
Where do you plan to find a SD rack, they are few and far between as used only. Don't go wasting money on under body armor, buy a goo set of diff guards and sliders and stay away from the rest since it really isn't needed. You know, you don't have a CDL, so you can't use lockers. Take your time building this up as you go so you don't spend money where it won't help you. Yell when you get ready and I'll show you where to get the better prices on the suspension. First thing you should do is go have your front drive shaft rebuild to prevent their common failure. Good luck, |
94 Defender 90
RTE rte product page
#4 (permalink) | |
Found an SD Rack (actually the LR Adventure RR) used that I pick up tomorrow for $825. Yeh, unfortunately I now know I don't have CDL, but I can put it in if I find one from an 04, correct? Bought it last summer and been researching/talking with community ever since to determine what works best. I'll admit it can be confusing, but I am a patient person, so I'll ask as I go. The guy I will off-road with have similar setups. I am ready to buy the suspension, so if you can point me to the best prices I would reallyappreciate it. When you speak of the front drive shaft, are you talking about replacing the u-joints with greasables? What would that cost? Can I drive with the front drive shaft removed? My DII has 50K on it and I notice a very slight rumble (not tires, etc.) at 55-65 that feels like the drive train. |
Yeah he is talking about rebuilding the front drive shaft with greasable joints. If you are capable of doing it yourself it won't be too expensive, if not I have heard it costing from $150.00 - $200.00 depending on where you are and who you use. It will be considerably less if you can take it off yourself and carry it in as opposed to having the place take it off, assuming you have something else to drive. You can also look into replacing the whole entire shaft if you want with a Tom Woods or A great Basin Rovers one. Umm you don't have CDL so I don't believe you can drive with out the shaft but I am not 100% on the '03, I have an '00 with CDL so I can drive with one shaft, BUT never offroad.
I think Cvc's goal is to make me vomit daily with his disgusting avatars. |
When you are decideing on suspension set it up for how you will drive 90% of the time. No good having soft springs for flex offroad if you carry heaps of wieght the majority of the time on road, likewise can't get heavy duty springs to carry a lot of wieght and expect them to flex up great.
Proberly the best compromise is to put medium springs and polyair bags, this will mean that you can set it up for what you are doing at the time, less wieght let the air out and decent ride and flex, more weight more air and retain ride quality. Go for reasonably firm springs at the front( not harse though) as this makes a big difference when going down steep hills, and won't really effect front end flex that much. Either way though OME is damm good stuff.
Smoke me a Kipper, i'll be back for breakfast! |
#8 (permalink) | |
2 Cruisers, 2 Rovers... I must be nuts!
Great Basins has a front driveshaft to replace the junk LR installed from the factory. Greasable etc. You cannot drive your rover with the driveshaft removed because there is no CDL. I would imagine from your description, the front drive shaft is ready to poop..... ![]() Best lift you can do and it looks good without TONS of other mods would be a 2" heavy duty spring kit from Steve at Rovertym. Go higher you are talking extensions for brake lines and a lot of other stuff..... |
#9 (permalink) |
I highly recommend the GBR driveshafts. Excellent product.
"In certain places, at certain hours, gazing at the sea is dangerous. It is what looking at a woman sometimes is." - Victor Hugo Originally Posted by Elemental Some guys play hard to get, I play hard to want. |
#10 (permalink) |
If you run the HD springs in the front and dont plan on bumper it may sit a bit nose high. Get the HD shock N107 and N108.
Check out WWW.Lucky8LLc.com 716-898-8153 Justin |
#11 (permalink) |
Both the 751's and the 779's are considered to be HD front springs. The 751's, although they were designed for the Classic, D1 and the Defender, give the D2 more support in a D2 the the 779's do if you are going to running a winch and bumper.
If you aren't going to go with the bumper and winch, stay with the 779, although still considered the HD coil for the D2, it will ride a little better unloaded. Mike |
| Thread Tools | |
| Display Modes | |
| Bearmach Heavy Duty Blue Springs DII, RRC, D1 | TNRRClassic | Land Rover Parts and Accessories | 10 | 09-02-2008 09:41 AM |
| Trade OME front med for heavy duty | mud rutts | Land Rover Parts and Accessories | 0 | 04-26-2007 10:56 PM |
| Heavy duty steering bars | Jones'y | Hybrid | 0 | 12-23-2005 01:20 AM |
| Wanting to buy medium heavy duty springs.. | xtremistSD | Discovery Series I | 3 | 08-16-2005 08:00 AM |
| question about heavy duty axles and spline count | MathewBGoode | General Land Rover Discussion | 0 | 07-24-2005 04:37 AM |
