Old 08-31-2007, 05:42 PM   #16 (permalink)
Roverhound's Avatar
Originally Posted by ROVERNIT
I hope they do www.rovertym.com because www.expeditionexchange.com dont
I have the RTE retainers on mine right now.
It just doesn't matter.
Old 08-31-2007, 06:31 PM   #17 (permalink)
Ian Matthews
p76rangie's Avatar
Could any one advise of where to get a good set of Spring Retentions from do they make one for D2 top and bottom
If your springs are actually 4 inches longer as you claim. You will not need retention devices.
Old 08-31-2007, 09:04 PM   #18 (permalink)
ROVERNIT's Avatar
I found rear from them and I think Scorpion do front ones
ROVERNIT is offline   Reply With Quote
Old 08-31-2007, 09:17 PM   #19 (permalink)
ROVERNIT's Avatar
Dont hate the player
hate the game
but please explain why you come up with this theory of why spring retentioners are not needed Im also intrested in finding out how you come with the conclusion to a statement made by you earlier like A 4 inch lift does not mean that they are 4 inches longer. They may be the same length as standard or only 1 or 2 inches longer. so which is 1 or 2 inches longer
I think all here understand that spring settle and my end up with 4 inch 3inch due to weight
Old 09-01-2007, 12:07 AM   #20 (permalink)
Ian Matthews
p76rangie's Avatar
You obviously have it all figured out. Dont let me stop you from doing what ever you are trying to achieve. I can only suggest that you actually do some research as to what you are doing and not just the components you plan to put in.
Old 09-01-2007, 06:04 AM   #21 (permalink)
Roverhound's Avatar
What shocks are you getting that you would need retainers in the front? I'm running 3" plus springs with extended shocks and don't come near to un seating in the front. The rear is a different story, that's where I'm retained.
In the rear,if you haven't done it already, you'll need to extend your watts linkage for the extra length to do you any good. That's taking into account the sway bars being disconnected.
I'd like to hear a bit more on your set up/ future plans.
Old 09-01-2007, 07:01 AM   #22 (permalink)
ROVERNIT's Avatar
I do have most of it figured out and it hasn't been easy I don't mind suggestions there ok it criticism that I hate have you ever done such a lift to disco 2
Old 09-01-2007, 07:14 AM   #23 (permalink)
ROVERNIT's Avatar
with the 4 inch springs I wanted to go with 12 inch traveling shocks however been advised that its a no no due to the extra upon the extras that need to be done
As for the watt linkage im getting them from RTE hopefully
I plan on running a set of Bilstein 7100 10 inch travel the retainers are simply to hold things tight Ive spent a fair bit whats another $30 even with the 10 inch travel the rears should not come out agian its to hold things tight I would have prefured to go the 12 inch shocks and retain my spring top and bottom
Unlike yours how ever all this runs around the ACE system which makes the planning hard hence why im trying to explain to P76ROVER that its been thought through and planned hard and done before
the idea behind this isnt mine so I cant take credit I have added my own thoughts in like the Bilsteins 7100 but the travel the rates are all copied and done before with great credit to Slunnie from ALROC forum the only thing that differs is my spring rates and shock in model only, he to runs bilsteins he doesnt run spring retainers at all I dont think 280 ibs front spring and 320 ibs rear Im running 220 ibs front and 280ibs rear he runs a bull bar and winch Ill run tube bar and winch he apperently loads her up which I dont plan to im going with lockers which go in on the 10th of this month cant wait I still need bump stops which I need to locate
Old 09-01-2007, 01:43 PM   #24 (permalink)
Roverhound's Avatar
Which Bilsteins are you going with? Do you have part numbers for the 10" and 12" travel shocks? I'll be updating mine soon.
Old 09-01-2007, 04:03 PM   #25 (permalink)
ROVERNIT's Avatar
Im buying them from www.eshocks.com
here are my to options
Part #: AK7110R06 Extended Length: 26.06" Collapsed
Length: 16.03" in 10 inch travel how ever two revalved to do 400/100
or
Part #: AK7112SB06 360/80 Extended Length: 28.06" Collapsed Length: 16.03for the front and for the rears Part #: AK7112SB99-400/100 Extended Length: 28.06" Collapsed Length: 16.03" 12 inch travel
to run the 12 inch travel I need to either have cones on the rear extra long brake lines extra long ABS lines and the impossible and no one makes them extra line ACE sway bar links if I could retain the spring top and bottom it would mean thing will only flex as much as the spring allows them to Ive got extra travel in the shocks which should prevent them bottoming out mainly give me more option in the future
these shocks are rebuildable so you can keep them for ever
Old 09-01-2007, 04:52 PM   #26 (permalink)
Roverhound's Avatar
Thanks.
Old 09-01-2007, 04:55 PM   #27 (permalink)
Ian Matthews
p76rangie's Avatar
It is a bit hard to suggest things when I don't know what you are trying to achieve. You say that you only have 33 inch tyres and may in the future go to 34's. These tyres can be fitted to a relatively stock D2 without guard trimming, etc.
You have already purchased or completed most the stuff, so it is a bit pointless making any suggestions. But it is clear that you do not know the specifications of the springs you are putting in. Therefore, it is not possible to work out the suspension travel you are going to have and therefore any suggestion in regard to the length of shocks is just a guess.
Old 09-01-2007, 05:08 PM   #28 (permalink)
ROVERNIT's Avatar
I do know the spring specs 100mm over standard as mentioned before and it has all been done before the shock lengths are the same however the spring rates differ a little, mine are 220 ibs front where as the its been done at 240ibs my rear spring are 280ibs where as the other was 320ibs
will it sit 4 inch higher then standard NO Im aware of that I would guess it will sit 3.5 inches and the length of the shocks wont make that much difference
the only thing here so far that I am uncertain about is the shocks rates 360/80 front and 400/100 rear I hope this isn't to stiff but again the shocks can be re valved
Old 09-02-2007, 02:47 AM   #29 (permalink)
Ian Matthews
p76rangie's Avatar
Therefore the springs are 4 inches longer as well as being heavier. This will give you a lot bigger lift than 4 inches.
As they are heavier, how much have they reduced your axle travel by?
Since they have reduced your axle travel, do you really need longer shocks or only reposition the standard shocks.
Again, it would be easier to offer advice if I knew why you were wanting to raise the vehicle 4 inches. As we know that you can fit the tyres you have/want under standard suspension, there has to be another reason for the lift.
Is the motor a TD5 or V8?
What do you have hanging off the front (Bull Bar, winch, etc)
Do you have a roof rack? If so, what do you carry on it.
Do you usually travel with yourself and maybe one other or do you have a car full.
How much weight do you carry in the back?
If you want advice on shocks, you need to supply more information that you are putting in springs that are 4 inches longer.
Old 09-02-2007, 05:34 AM   #30 (permalink)
ROVERNIT's Avatar
What are the spring rates standard ?
Why would it reduce my axle travel?
if buy chance it would have reduced my axle travel which clearly it wont why would I drop my mounts 2 inchs to run standard shocks when the vehical will be raised 4 inchs, perhaps I see the piont if I was doing a 2 inch lift I could do this but why with a 4 inch lift?
Im currently running 265x75x16 and at a particular turn it scrubs on the mud flap no biggy I would see it piontless to have 33 on standard lift though
the reason why Im lifting the D2 four inch is due to the terrian I like and where I like going, previous to the Discovery I had a GU Patrol it started with 2inch lift and ended with a 6 inch lift and 35 I like doing the hard stuff its as simple as that nothing more nothing less
its a V8 Auto didnt like TD5s drive
nothing yet bar and winch to come next week
not as yet but may might have a roof top tent as well very soon
Depends when going a way theres 2 adults and a little one
How much weight do you carry in the back? .
Only a fridge at this stage draw set to come
to be truethfull all I only wanted was product info as for the shock size and rate I already know and rather then guessing as most would be doing Im copying what has been done and proven as many stated you pay for what you get and procomps are just that as advised by many that there was alot of good and bad as per ranchos so I said stuff it and went bilstein
as mentioned I wanted spring retainers not that the spring will pop out however will do if I go a 12 inch how ever shouldnt if I go a 10 inch but more to secure the spring and stop them from clunking etc
the watt linkage is sorted a front ACE links will be going on rears already have extended ABS and brake lines need bump stops however Im going to get ones that sit over the piston rod to protect the shock from bottoming out Im getting wheel spacers to widen the stance was going to go with 285 but advised the standard rims where to small and will wear out to quick will at a later stage get a set of 34 dont want to cut guards / fenders to get 35 but hay may change my mind im getting Diff locks ARB or Maxi Drivs did book in the ARB but uncertian there you go give me advice here where I want it
