#46 (permalink) | ||||||
Cheers Slunnie Disco2 TD5, SeriesII V8 ute. |
#47 (permalink) | |
#48 (permalink) |
Majesticdisco1
Alright I have to say this
looking at the pictures from what I've seen I love how Aussies build their Discoveries. quite a different take from us American Rovers cool ![]()
1996 D1 J "Crawler" camo,33x10.50's ![]() |
#49 (permalink) | |
Out of line agreed but im still currious to why his a landy man but not on AULROC member and after the bites I get from member there (which I fuel) I have come here for tranquility) and curious to what his story was with AULROCIm not slide tackling Ian at all but he is stubbern ![]() |
#50 (permalink) | |
No not really Dude there are only a few extremists from what I gather Slunnie is the forefather when it comes to D2 ![]() |
#51 (permalink) | |||||
Ian Matthews
The discussion I raised in this thread is not whether the mods mentioned can be done, but why would you do it if you were only fitting 33 or 34 inch tyres.
If you read the intro, it states that they have been adopted by all states. What you are suggesting is that cars in NSW do not have to comply with ADRs. An engineer's certificate does not make a car roadworthy. The certificate only states that the mods are safe. I would be surprised if you rang your engineer today that he would approve 35's. Even vehicles in various states have been told that even though their vehicles have been previously engineered with 35's, they can no longer legally run them. Quote:
Yes I run heavier springs due to the extra weight of LPG tanks, front and rear bars, winch, etc. I run 220's in the back (std is 150's) and 170's in the front (std 133's). So about half the height increase is through the stiffness of the spring, but the springs are also 1 inch longer than standard. I go for length first and then make up what I have to in stiffness. I have stuck to off the shelf springs. |
#52 (permalink) | |
Ian Matthews
He invited me on this trip along a track I had done many times. I had taken relatively standard vehicles (mud tyres though) up this track in the past without any great difficulty. Even did it as a night run, both up and down. The pictures I posted above are from this track. But it is the type of track that you can come unstuck if you don't use your head (or listen to others). I knew that these guys would end up breaking something, even though they were relative well set up rangies with Simexs, diff locks, maxi-drive axles, etc. I am not breaking my Rangie recovering idiots, so I said I would come along as a passenger and left the Rangie at the organiser's house. We were less than half way along the track when my predictions started to come true. The first one blew something in the front, from memory it was a diff. So the remaining 3 vehicles had to connect up to start towing him up the track. Not much further on, a second one with too much right foot blew his front CV. But did he stop, no, not until he blew the second CV. So 2 cars with only 2 wheel drive and 2 cars left to pull them. Tried getting one to the top at a time. Nearly got to the top and the 3rd rangie noticed his gearbox lever disappearing through the floor. He had managed to rip out 3 out of the 4 engine/transmission mounts and the motor and gear box was about to fall out. He managed to get to the top with some winching, but could not help with the other 2 damaged Rangies. So the only car left was the only one that knew how to drive (the guy I was passenger with). By this stage it was dark and we had no torches, etc. Walking around a wet slippery track, when you could not even see your feet, became very interesting and ended up on my arse a number of times. Finding winch trees was near impossible in the bush. The last remaining Rangie gave it a good shot, and nearly got the other two to the top, but winch and battery died and the clutch slave cyclinder gave way. So we strapped the motor and gear box into the Rangie at the top and drove out to get my Rangie. I came back with lights and a winch and finished the recovery (they only had a couple of hundred metres to go). So I was proved right, we got to the top after midnight, and I still refuse to go out with idiots that can't drive. |
#53 (permalink) | |
thats fair enough I feel there isnt much driving on the site more ranting and raving then anything else Ill let your self and Slunnie slug this one out hehehehe Ill read and take note hehehehe |
#54 (permalink) | |
#55 (permalink) | ||||||
A 2" lift + 2" body is a different setup to a 4" lift though. The D2 is a lot more accepting of that type of thing than a RRC. Interestingly, a D2 will naturally keep increasing its roll resistance as it leans, which the RRC/D1/Def doesn't due the rear suspension design.
#56 (permalink) | ||
Ian Matthews
What I find is that it is not the height of the tyre so much, but the width of the tread. With the lugs on the Simex, they are a lot harder to fit. The actual tread width on the older BFG (and most other tyres) is nowhere near 255mm. From memory, I think they were around 230mm. The 255 measurment is always taken at the widest part of the tyre, about half way up the sidewall where the tyre bulges the most. Quote:
"Normally to modify a Land Rover to run larger wheels we would use a body lift kit. Unfortunately it is ILEGAL to fit body lifts to and SRS vehicle in Australia. This limits what we have been unable to do with the D2's. Working with our engineer we have final;ly found the way through the legal loop and it is now looking very promising that we can create the D2's with 35" tyres, Offset rims and our XL flares. We are still doing some prelim work but all is looking good. Was all looking good until the new rules in April 2006. This has outlawed the use of tyres larger than 33" for Australian roads. With the D2 it is possible to run a 32" tyre 265*75*16 with only a minor suspension upgrade without flaring etc. For this reason we have put the moulds for the D2 flares on the back burner. They do look good though!" |
#57 (permalink) | |||
